Plex client not loading/displaying library on firetv.
Ds24mr
Re: Plex client not loading/displaying library on firetv.
Post by Ds24mr »
No sorry, Firetv 1 Stick.
Ds24mr wrote:No sorry, Firetv 1 Stick.
FireOS waits for tvOS testflight feedback before we push out 2.6.3 for all.
Ds24mr
Post by Ds24mr »
Ok tnx and good luck ;)
Jungle_Jon
Post by Jungle_Jon »
Still not working. Will post a log later.
Ds24mr
Post by Ds24mr »
No update since 2.6? 2.6.3 is not online, did you know when we can find a solution? :roll:
Post by cosmoxl »
Ds24mr wrote:No update since 2.6? 2.6.3 is not online, did you know when we can find a solution? :roll:
the firetv doesn't show the third digit for app builds but it is 2.6.3 if you have the latest update.
Ds24mr
Post by Ds24mr »
Ok cool, i deinstall it today and Check again!
If it is not working, what can i do?
Ds24mr wrote:Ok cool, i deinstall it today and Check again!
if its still not working, we do need to see debuglog from the latest MrMC 2.6.3 version as that has more logging for us to see why or where it fails to get content.
would help to know what Plex server version you are using as well, it could be that its "too old". I am not sure how stable Plex API is and if anything changed from the earlier versions.
Ds24mr
Post by Ds24mr »
Ok, i test it, my Server is up to date.
Ds24mr
Post by Ds24mr »
Hi. I get no connection,
I cleared the Cache. Delete all Data. And doin a fresh install.
@First i activated the debug log, and then i try d to Login in plex via Pin.
Here is the log
http://pastebin.com/veRsjHip
In settings System Info i see build 2.6 git 2016-09-11 is this up to date? I dont know where to find a up to date Version if my one is old.
My Plex Server is Version 1.1.4.2757 on a Windows 7 ultimate.
