Testing MrMC 3.9.7 - Apple TV
Montoya
Re: Testing MrMC 3.9.7 - Apple TV
Post by Montoya »
amet wrote: 25 Apr 2020, 19:44
cosmoxl wrote: 25 Apr 2020, 18:05 stutter with live tv with tvmosaic with OSD up seems fixed!
thats great news!
Seems like the DVBLink PVR improved too regarding this subject, so it looks like an overall fix instead of a tvmosiac PVR only fix, correct ?
Montoya wrote: 25 Apr 2020, 20:52
thats great news!
tvmosiac PVR only.
https://github.com/MrMC/pvr.tvmosaic/co ... 7e09360596
Climiu
Post by Climiu »
Thanks for capitalizing the home strings. With Media Sources now capitalized, in the Settings menu can we also capitalize to System Information and File Manager for a more uniform look in this menu too. Not the biggest deal I know but would look better this way. :)
3.9.7 (200428.47)
- capitalize System category texts
- bport: fix smi subtitles to use quoted start tags
- bport: settings, add "Dark Grey" subtitles color option
- bport: add subtitle(text) opacity
- Mediaservices: list Shows and seasons from home screen
- jellyfin: not all servers have ServerPropertyLocalAddress
- plex: fix fanart display error
dietcokke
Post by dietcokke »
Testing against the new build I've noticed that TV Shows don't seem to sort by episode order when looking at a particular season. I can't test against the Emby connection to see if it's just an issue with the Jellyfin connection type. Not sure if this is a known issue or not.
What sort order is it under? If you click left from episode listing you can see what it is now
dietcokke
Post by dietcokke »
I did have it by name, which does explain why they seemed to be out of order there.
But, I can't seem to find a sort that sorts by the actual episode order. Seems like the closest I can get is "Date Added", but if they're all added on the same day it doesn't result in the actual episode ordering.
Should I move this to somewhere else in the forum?
Edit: Nevermind, I realize I'm an idiot. It seems that File sort seems to put them in the correct order.
dietcokke wrote: 28 Apr 2020, 18:50 I did have it by name, which does explain why they seemed to be out of order there.
maybe that should be the default?...
anyone else see issues on Emby/Plex sort order?
Climiu
Post by Climiu »
Mediaservices: list Shows and seasons from home screen and plex: fix fanart display error is now working just fine. Thanks for the fix!
fixed sort issues.. since you changed your setting it might default to something else other than Episode.
thanks for the info
