And I'm seeing NO logo's at all. The code pastes where from the MrMC log, running seperate MrMC profiles each. One for TVMosaic server and one for DVBLink server. Did you look at the end of each line what MrMC sees for mimetypes of the png's from the channel logos ?
Testing MrMC 3.6.1
- Montoya
Re: Testing MrMC 3.6.1
I am using test server that doesn’t belong to me, and as both of us are saying... logos are fine
New version is coming out with hopefully fixed timeshift , hopefully in the next hour or so
Clear data when you switch between 8100 and 9270 ports and let’s see the log again from that
- Montoya
Will provide logs of new release when its out, to see if that fixes it.
Which email I can use for sending logs of new release ?
tvOS Testflight is pending on Apple servers, should be clear within an hour
3.6.1 (180406.738)
pvr.dvblink: fix for TVMosaic servers
3.6.1 (180406.738)
- Montoya
Still pending it seems on the Apple servers.amet wrote: 06 Apr 2018, 09:21 tvOS Testflight is pending on Apple servers, should be clear within an hour
In the mean time, I have just sent you guys a log by mail for investigation.
3.6.1 (180406.738) should be out now in TestFlight
- pvr.dvblink: fix for TVMosaic servers
jaas66
Thanks! After quick test Timeshift worksamet wrote: 06 Apr 2018, 15:32 3.6.1 (180406.738) should be out now in TestFlight
new update crashes my DVBLink server when I stop playback of live tv (tested both using the menu button and clicking stop in the OSD)
https://paste2.org/eDyaK0LA
The server seems to eventually recover but for a while it's down - while it's down I can't access control via web GUI and attempting playback of a live channel I get warning that it couldn't be played. If I wait a bit it all works again until the next time I stop a live channel.
- Montoya
Feedback TVMosaic server:
1) Timeshift is working perfectly, so thank you guys !
2) Still same issue with channel logo import
New log is sent already by mail.
Will test now with DVBLink server, instead of TVMosaic server.
