Testing MrMC 3.6.1
jaas66
Re: Testing MrMC 3.6.1
Post by jaas66 »
amet wrote: 05 Apr 2018, 19:12 For dvblink, please clear data
Settings -> tv - > general - > clear data
I suspect that channel ids were saved as long before and are now being sent as string
Did an attempt, unfortunately did not help, same problem
jaas66
Post by jaas66 »
jaas66 wrote: 05 Apr 2018, 19:28
Did as follows
1, clear data
2, restarted server
A little different behavior before and after that:
Before: received an error message in MrMc that "can not start the channel, check the log" freely translated from swedish ;)
After: MrMc crashes when try to play a channel, but can be restarted immediately
I am testing now using your server and all is ok... I am using same testflight 2018-04-05
I wonder whats different here vs on your side.. what happens if you use your ****.net adress for host vs local lan IP?
EDIT: I see it crash now, if I enable transcode and timeshift.. are you both running the same?
jrcorwin
Post by jrcorwin »
I am still having an issue with the audio delay on the latest TestFlight version. It has improved however. I’ve gone from needing an offset delay of 0.250ms to now only needing 0.100ms.
MrMC passthrough is off
MrMC Adjust Display Refresh Rate set to Always
MrMC Sync Playback to Display is off
MrMC set to 7.1 channels
tvOS and MrMC set to match frame rate
tvOS set to "best quality available"
No ARC
Same issue regardless of codec
jaas66
Post by jaas66 »
amet wrote: 05 Apr 2018, 20:08 I am testing now using your server and all is ok... I am using same testflight 2018-04-05
Disabled Timeshift and it works :)
jaas66 wrote: 05 Apr 2018, 20:34
ok, great... so let me see where we crash :)
Montoya
Post by Montoya »
amet wrote: 05 Apr 2018, 20:08 EDIT: I see it crash now, if I enable transcode and timeshift.. are you both running the same?
Only Timeshift was enabled during my test.
Will test later after my wife frees my Apple TV and report back.
jrcorwin wrote: 05 Apr 2018, 20:25 I am still having an issue with the audio delay on the latest TestFlight version. It has improved however. I’ve gone from needing an offset delay of 0.250ms to now only needing 0.100ms.
No ARC
please double check that your av receiver does not have any audio offset applied. Same for hdtv.
jrcorwin
Post by jrcorwin »
davilla wrote: 05 Apr 2018, 22:43
No ARC
Nope. None are applied with the receiver or TV. Just the 0.100ms offset in MrMC at the moment.
Montoya
Post by Montoya »
Tested with timeshift disabled, channels play from TVMosaic server.
amet wrote: 04 Apr 2018, 16:16 channel logos are working fine here, few seconds and they show up.
Concerning why channel logo's won't show in MrMC from TVMosaic server:
TVMosaic:
00:27:40 T:6096711680   DEBUG: CCurlFile::GetMimeType - http://xxx.xxx.xxx:yyyy/stream/playback?object=13868c28-a9ad-4432-a90d-c4f161b57b99%3aNL_logo%2fEurosport+1+HD.png -> video/mpeg
DVBLink:
00:35:31 T:6110195712   DEBUG: CCurlFile::GetMimeType - http://xxx.xxx.xxx:yyyy/dvblink/playback?object=c4bb498b-0542-46d8-a13d-59abef042af4%3aDE_logo%2fWDR.de.png -> image/jpeg
So channel logo's from TVMosaic are categorised as video/mpeg in MrMC, instead as image/jpeg, as seen in example from DVBLink.
Do you still need debug log and if so, can I send that by mail, so I don't need to clean it.
