Happy to report this is fixed in the latest update.BillyBudapest wrote: 10 Jul 2019, 19:39 TV section on Home Screen missing after update 7f3ef47 (also happened with previous one but just able to post now)
Can get it back via settings, Media sources, PVR clients, Tvheadend HTSP Client, Configure, OK
However after quitting and restarting MrMc it's missing again.
https://pastebin.com/d7zx103M
BillyBudapest
Re: TV section on Home Screen missing after update
maglione66
Hi, any chance that subtitles in bluray and bdmv folders are less bright, like kodi 18?
Thanks!!
Thanks!!
- koying
In HDR, I guess?
maglione66
Yes, yes.
gacama
Tried latest beta, no stuttering with advanced timing off, but there are an important delay between audio and video
how important ?gacama wrote: 24 Jul 2019, 15:31 Tried latest beta, no stuttering with advanced timing off, but there are an important delay between audio and video
gacama
I agree. I see more sync problems with advanced timing off but no choppiness or what seems like frame skip.
With advanced timing on, which is how I run things normally, I still see things become choppy with 25fps material. With 23p material it doesn't completely become choppy but it begins to skip a frame every second or so. Usually I skip back or stop and start and it fixes things.
Audiomixer
I do not run advanced timing on due to the choppiness factor. As far as sync, if I uncheck passthrough format is IEC Packed, sync is pretty much spot on for me at least and I have had not further issues.cosmoxl wrote: 26 Jul 2019, 15:30I agree. I see more sync problems with advanced timing off but no choppiness or what seems like frame skip.
Shield>denon x4500>Lg C8
you're right. changing to raw passthrough and "dumb" timing seems to work well.Audiomixer wrote: 26 Jul 2019, 16:19I do not run advanced timing on due to the choppiness factor. As far as sync, if I uncheck passthrough format is IEC Packed, sync is pretty much spot on for me at least and I have had not further issues.cosmoxl wrote: 26 Jul 2019, 15:30I agree. I see more sync problems with advanced timing off but no choppiness or what seems like frame skip.
