Angryunibrow
Re: Testing MrMC 3.7.1 for Google Play
Post by Angryunibrow »
whinette wrote: 27 Dec 2018, 13:27 Hello,
I have problem with ac3 decoding with latest beta. My receiver plays sound for one second then nothing then sound etc.
Also I have problems with plex for kodi, the last row doesn't display in full (cf photo):
I have this same issue, you cant see the last row and when you get to the bottom of the list and press down it jumps you to the top of the list.
Rootax
Post by Rootax »
Same problem here. I made a thread with some logs, I hope it can be fixed soon.
Anyway, happy new year all :)
hieyemtim
Post by hieyemtim »
Is "IEC packed" compressed? Will raw audio support be coming in the future? Thank you all for your amazing work! Happy New Year!!!
jcwillia1
Post by jcwillia1 »
Watched matrix relaoaded fight vs all the smiths and I am
getting way too much audio from my side channels and nothing from my fronts?
Error from the disc?
Post by koying »
hieyemtim wrote: 02 Jan 2019, 01:19 Is "IEC packed" compressed? Will raw audio support be coming in the future? Thank you all for your amazing work! Happy New Year!!!
"Raw audio"? AC3/DTS/... are all compressed. Only PCM is "raw", as in decompressed by MrMC.
Passthrough is untouched, by definition, and pass the compressed AC3/DTS/... to the AVR for decoding.
IEC or not only defines who "wraps" the compressed audio for transportation on the HDMI cable. IEC checked means MrMC does it, unchecked means android does it.
hieyemtim
Post by hieyemtim »
Thank you so much! You’re the absolute best
SUPERBIF
Post by SUPERBIF »
I have problem in video playback after pressing info, when I then wants the info screen to go away I press back and sometimes it go away but sometimes it doesn't and when I press back again it exits the video. Using Ariana skin, don't know if it's skin related or not.
khalid
Post by khalid »
Angryunibrow wrote: 31 Dec 2018, 03:22
I also have the same issue with regards to not being able to see the last row in the plex for kodi addon.
Other than that, this is my favorite way to use plex.
fixed missing last row, will be in next release
sram16
Post by sram16 »
I've been having network disconnects/timeouts in the last couple versions of MrMC on mkv playbacks, the exact same issues described in this reddit thread
https://www.reddit.com/r/ShieldAndroidT ... t_of_time/
https://forums.geforce.com/default/topi ... solution-/
Is this a known issue? There's a log in the link
