He just means its possible in general with the right Dolby insiderinfo which we will never get. So ofc no Dolby Vision coming and its a HUGE shame. It would boost the Apple 4k big time many would buy it immediately myself included a new DV era would begin it would change mankind....
But no chance
I want to buy the Apple TV 4k and play dual layer DV stuff that would be out of this world. How much money for support do you want davilla? 50 bucks? ^^
Dolby Vision
barong
Re: Dolby Vision
If this is such a life changing feature, why not buy a DV blu-ray player and be done with it???Godmax wrote: 04 Oct 2018, 11:17 He just means its possible in general with the right Dolby insiderinfo which we will never get. So ofc no Dolby Vision coming and its a HUGE shame. It would boost the Apple 4k big time many would buy it immediately myself included a new DV era would begin it would change mankind....
But no chance
- timstephens24
Re: Dolby Vision
barong wrote: 04 Oct 2018, 23:48
Un4given
Re: Dolby Vision
so, can MRMC play Dolby Vision in general? i have a .iso file and it is only HDR found no Dolby Vision.
I understand it is not jet possible with DL, or is it not possible in general?
- timstephens24
Re: Dolby Vision
In general, it can play Dolby Vision but as mentioned before only the single layer found in normal streaming files. Dual layer tracks like what's on a UHD disc that have been ripped to a file can't be played on any streaming device.
Godmax
Re: Dolby Vision
Enough is enough. Bought an Oppo 203 weeks ago. Either you go with DV into the future or no DV at all.
Re: Dolby Vision
Let’s see what porn industry decides, that’s where the decisions are made.... Beta vs VHS and Blu-ray vs HD DVD comes to mind
Godmax
Re: Dolby Vision
So far a year with lots of DV material and no HDR10+ stuff whatsoever. So far it is decided....maybe next year we will see a bit of HDR10+ but thats about it
Grencola
Re: Dolby Vision
Uhhhh so did this guy seriously just figure out how to make a working DV MUX!?? Can someone with MrMC and Apple TV 4k and/or an LG Oled TV please test this like asap??
https://www.reddit.com/r/Piracy/comment ... it-android
He said the first step is to demux your mpeg4 (possibly even mkv as it does actually store the DV EL still) or m2ts.. Well, the largest m2ts from a UHD BD-Rip can be found in the bdmv\stream folder, and then TSMuxer program shows both the BL+EL (Base Layer - uhd hdr10, and Enhancement Layer - 1080p DV) and it has a demux option you can select which should split it apart.. then just follow what he said in step 2 and 3 to add them back into that Dolby Mp4 Muxer program and test out your new single layer DV mp4??
Godmax
Re: Dolby Vision
Doesnt work with that command line shit he posted. "progress" is an unknown command.
