testing MrMC 3.0.9
Re: testing MrMC 3.0.9
Settings -> services-> trakt
It will be in a next TestFlight version
jabohn
Post by jabohn »
Cool, I'll give it a try after the next testflight.
Post by timstephens24 »
amet wrote: 06 Jul 2017, 20:51 added trakt.tv bulk pull and push watched status, anyone brave enough to test? :)
I'll definitely try after it's pushed.
jabohn
Post by jabohn »
Hypothetical situation - say if I had a new deice that I installed MrMC onto from scratch, once I sign into Trakt would it then correctly mark my entire library?
jabohn wrote: 06 Jul 2017, 22:59 Hypothetical situation - say if I had a new deice that I installed MrMC onto from scratch, once I sign into Trakt would it then correctly mark my entire library?
I'm testing that now...
I got the new update and then signed out of Plex. I added all my BluRays and TV Shows (523 movies and 1960 episodes) and then ran the "Pull Watched Status from Trakt.tv server" and waited...
I have to say, it worked brilliantly. I love it. But only for TV Shows. It didn't do anything for the movies lol. The log was too huge since I added my library, so I cut out everything I think you'll need:
https://pastebin.com/v46nNtic
I force closed MrMC and opened it up again and tried to pull from Trakt again to see what would happen. Apparently it would crash:
https://pastebin.com/BwHXRidm
jabohn
Post by jabohn »
I'm connected to Trakt.tv now but I have a suggestion... the window that pops up with the instructions to activate and the code to put in, could that be made larger? For starters, it will be easier to see from a distance and also it will fit in the box without having to scroll.
ALSO what's the error about duplicate entries?
timstephens24 wrote: 06 Jul 2017, 23:23 I force closed MrMC and opened it up again and tried to pull from Trakt again to see what would happen. Apparently it would crash:
new TF is uploading, I have added some more logging to see why your movies fail to sync, works here on multiple attempts.
jabohn wrote: 07 Jul 2017, 00:02 I'm connected to Trakt.tv now but I have a suggestion... the window that pops up with the instructions to activate and the code to put in, could that be made larger? For starters, it will be easier to see from a distance and also it will fit in the box without having to scroll.
unfortunately not, the skins dictate the text. I'll make it 2 separate lines.
Warning is cos it happened that it uploaded watched status for items that are already marked watched in trakt. We have addressed those, should be fine now.. once all is confirmed that warning might go away(or we might keep it to COA)
