testing MrMC 3.1.0
Re: testing MrMC 3.1.0
jabohn wrote: 06 Sep 2017, 23:33
davilla wrote: 06 Sep 2017, 18:11 20170906-f79f901
height of progress lines increased , 6 -> 10
tvOS/iOS for now.
I'm good with this. If some complain, I don't mind it a bit thinner.
Also, any chance of the "All Seasons" being fixed or is that going to wait for the next test? It shows up in wall view despite being turned off. Thanks!
Only shows in wall view? Did you report this issue as I don’t remember seeing it?
Everbrave
Post by Everbrave »
timstephens24 wrote: 06 Sep 2017, 22:11
Everbrave wrote: 06 Sep 2017, 21:12 One of the things I like about you guys is that you "respond" and fast; that is actually a big deal; Thanks for the continued effort.
It seems like they actually care about their app or something. Crazy..
I guess they like what they do 😉
jabohn
Post by jabohn »
amet wrote: 07 Sep 2017, 05:20
tvOS/iOS for now.
Yes I mentioned this a few times back when the wall view was put into the new skin. It only shows up in wall view.
jabohn wrote: 07 Sep 2017, 15:24
I can’t reproduce this, if I enable “all seasons” it shows in both views... same if I disable it, it’s hidden in both.
Looking at the code, it’s not skin specific... do you see it on other skins? What library are you using?
jabohn
Post by jabohn »
Yes, I see it in multiple skins. My library is just an SMB share on my iMac.
and you disabled "All items" in settings? As I say, it all works fine here, not sure why you are seeing the issues :(
jabohn
Post by jabohn »
amet wrote: 09 Sep 2017, 06:58 and you disabled "All items" in settings? As I say, it all works fine here, not sure why you are seeing the issues :(
My bad. At some point testing the new skin, that All Items option was enabled. However to me it's named wrong. I was looking at the option directly above it, and had set it to "Neither", which I thought was the option I was looking for.
Ted377
Post by Ted377 »
Can you add an extra menu point like DVD / Blu-ray?
Then I could integrate this directly from my NAS and query.
PS: I like the new design from the forum 😊
Ted377 wrote: 10 Sep 2017, 16:48 Can you add an extra menu point like DVD / Blu-ray?
Not sure I understand “extra menu point” :(
... and nothing else is allowed to go into 3.1.0 as it’s now going up to app stores for a release.
PS: thanks, you are the only one that noticed :)
jabohn
Post by jabohn »
I noticed!
