Noob - How do I feed the library off a Plex server
Re: Noob - How do I feed the library off a Plex server
NeilFawcett wrote: Do you want any logs? Or have we gone past wanting those now?
we have gone past needing them :)
I am 100% sure the issue is there as we have experienced the same issue before which seemed to be fixed according to this 14 page thread... viewtopic.php?f=19&t=743&start=130
some AFTVs were not returning gateway and it gets stuck there... I thought we fixed that :(
thanks for testing and helping out
NeilFawcett
Post by NeilFawcett »
And you hope if I return the FireTVs network setting to default, or back to a hardcoded IP address (I'll follow your link), that could solve it?
Strange how Plex works of course no the same FireTV!?
ps: Thanks for all your help on this! Especially the speed of it!
NeilFawcett wrote: And you hope if I return the FireTVs network setting to default, or back to a hardcoded IP address (I'll follow your link), that could solve it?
yeah, if that works we can try to identify why it was not working with previous settings.
NeilFawcett wrote: Strange how Plex works of course no the same FireTV!?
I am not surprised that it works with plex app, its designed to only connect to Plex Server, we do it differently ... that loop I pointed earlier is designed to keep connecting (but as you see its not perfect :) ) once application becomes focused.
NeilFawcett wrote: ps: Thanks for all your help on this! Especially the speed of it!
happy to help, at work ATM and cant look into all the aspects but we can throw ideas around :)
in Settings -> System info -> network ... what do you see?
NeilFawcett
amet wrote:in Settings -> System info -> network ... what do you see?
I noticed no gateway - http://i.imgur.com/1PKP2mv.jpg
Went into the FireTV settings and no gateway and no DNS2, so went through them again, and a gateway defaulted in (192.168.0.1) and entered in DNS2 - http://i.imgur.com/dn137F7.jpg
Ran MrMC, still no gateway.
Uninstalled MrMC... Reinstalled... And... Still a blank gateway? Redid my Plex PIN and didn't work.
Is the blank gateway causing the issue do you think?
Should I remove my hardcoded network for the FireTV?
If there is no gateway there will be no content....
just to verify, this is a firetv1 ?
NeilFawcett
davilla wrote:just to verify, this is a firetv1 ?
This is the latest/current one... Got it 3 months ago.
NeilFawcett
amet wrote:If there is no gateway there will be no content....
Well the FireTV is showing a gateway... And MrMC isn't?
Only thing I can think to do is to try and return the FireTV back to automatic network settings?
NeilFawcett
Told the FireTV to forget the hardcoded network... And voila! Working as soon as I went into MrMC!
Thanks for getting me to this stage...
I'll give it a few days... Then re-hardcode it out of interest. if that then breaks it again I'll update this thread...
