The new format is not properly applied to special episodes on the home screen.
Example with the mandalorian in the picture
The standard text is okay S0:E1. But once you select the episode you just see S01. Directing. This should be S0:E1. Directing.
Top Shelf Category Order
- Waltman
Re: Top Shelf Category Order
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
It’s S for specials, that’s how it always was
Climiu
Yeah I thought I would give it another day to see if I just needed to get used to the . following the E and if it would grow on me. But unfortunately I have to say the . still feels out of place with our new format in all of the List, Fanart and Wide view options. For a quick visual, here is an example showing that it doesn't look right imho:jabohn wrote: 16 May 2020, 19:34I agree. I just noticed the change recently and it looks messy to me. I would get rid of the period after the episode number for sure, and have either just a space or a dash as mentioned above.Climiu wrote: 16 May 2020, 17:55 I'm not completely sure if S1:E12. Episode name is the best look for our new format. The . at the end worked okay before in the List view when we used just numbers only but something about it just doesn't look quite right now especially in the Wide and Fanart view options. I associate a . being used in numerical lists and this isn't really the case in Wide and Fanart.
Perhaps a more universal format that would work better in all screens could be used such as
S1:E12 - Planetfall
This was changed, just holding the TestFlight yo address all the issues
