I guess people will move to Ariana which shows it properly or you'll have a lot of complaints same as me. It just doesn't make sense to show TV eps in the in progress section of movie libraries.amet wrote: 23 May 2018, 20:36Not much to fix.... that’s what plex gives us backcosmoxl wrote: 23 May 2018, 16:28bump.cosmoxl wrote: 23 May 2018, 02:18 I've got the latest build.
In Opacity I noticed an episode (TV show) I'm in the middle of is showing up in the "in progress" section of movies - odd.
In Ariana the same episode is showing up in "continue watching", separate from "on deck". That makes sense.
Log here https://paste2.org/wAv5dVpM![]()
If you look in plex webui it’s exactly the same, so we have 2 options... sniff out the offending episodes and not show them or rename that section to onDeck and copy the plex webui 100%
Re: Testing MrMC 3.7.0
jabohn
I have MrMC only and the Server button shows up, first little one on the bottom left.pecinko wrote: 23 May 2018, 16:14Photo, please? If you have mrmc only, there should be no server button as there would be no use for it.logan_x50 wrote: 23 May 2018, 15:34 @pecinko, just below the new server source button there's a couple of funky characters. i checked opacity and that's fine. my server source is mrmc database btw
Also, new problem with the new build which I just installed. In Progress has suddenly been populated with everything I've already watched. Even updating the library doesn't clear the list. They are all marked as watched. I don't use Plex or anything, just an SMB share from my Mac.
hehe, what you seeing is exactly the same as ariana, its just @pecinko playing tricks with you ... he calls it "Continue watching" and it still has all the content mixed in ...cosmoxl wrote: 23 May 2018, 23:22I guess people will move to Ariana which shows it properly or you'll have a lot of complaints same as me. It just doesn't make sense to show TV eps in the in progress section of movie libraries.amet wrote: 23 May 2018, 20:36Not much to fix.... that’s what plex gives us back
If you look in plex webui it’s exactly the same, so we have 2 options... sniff out the offending episodes and not show them or rename that section to onDeck and copy the plex webui 100%![]()
I'll see what we can do to filter it out if it hurts that much
amet wrote: 24 May 2018, 04:30
Otherwise Opacity does NOT mix. Highlighting movies libraries in the left section shows movies in recently added and in progress section. Highlighting TV shows in the left section shows TV shows in recently added and in-progress.
If Opacity was like Ariana it would show movies and TV mixed no matter what library is highlighted in the left section.
(180524.438 @826dfe)
actors: add monogram for video info screen
plex: cleanup SearchPlex(), do not attempt to retreive information if size is 0.. there is nothing there
- pecinko
If there is someone with decent upload bandwidth who’s willing to give me temporary access to his/her PVR backend in order to finish PVR support in Ariana skin - send me a personal message, please.
- vlaves
Donepecinko wrote: 24 May 2018, 15:27 If there is someone with decent upload bandwidth who’s willing to give me temporary access to his/her PVR backend in order to finish PVR support in Ariana skin - send me a personal message, please.
- pecinko
It's rocking here already. Many thanks!!
- vlaves
You trying to tell me something?pecinko wrote: 24 May 2018, 15:27 If there is someone with decent upload bandwidth who’s willing to give me temporary access to his/her PVR backend in order to finish PVR support in Ariana skin - send me a personal message, please.
