Same, Tv Shows link on the main screen points to a directory of folders (drives where the tv shows are stored in emby) instead of displaying all the Tv Shows.brallor wrote: 26 Feb 2019, 13:20 Hi,
I want to test 3.8.0, have problem with Emby client integration
Testing MrMC 3.8.0 - [Invites Closed]
automated
Re: Testing MrMC 3.8.0 - [Invites Closed]
solamnic
https://imgur.com/a/2I1WHkqThe first 2 images are by playingback with AVCodec (1080p file) (LG OLED B7)
the other 2 images are with the Videotoolbox..
In the start you can see the white filter that is applied to the whole movie when playing back with Videotoolbox while AVCodec produces more accurate colors.
(Apple TV Settings 4K SDR - Match Frame and Range)
There is no 'white filter' being applied. Something going on with SDR/HDR mapping.solamnic wrote: 27 Feb 2019, 13:30Better with images..Code: Select all
solamnic
that only happens with videotoolbox..
not with my hdtv
When playing a video with videotoolbox is the brightness set way high accidentally in video settings?
solamnic
Same settings on TV that are on AVCodec...
BTW when playing back with videotoolbox - in the pictures i ve previously attached - one can see the black bars up and down on the movie that they have the correct color.. the movie colors are not correct,
btw my brother in law who has the same tv (and mrmc-appletv) also experiences the same problem, so he is also using the avcodec..
oled technology maybe?
BTW...
I maybe managed to solve the problem with the ticking sound..
Audio - Play Gui Sounds -> i set it to NEVER..
and the crappy ticking noise seems to have gone.. will also report after more testing..
There's another setting that might help with the ticking noise.
To keep an a/v receiver 'alive' with respect to audio, MrMC outputs audio 'silence'. It's not pure zeros but a very low level of random PCM. There's a setting that controls the level.
settings, system, audio, 'level of inaudible silence',
default
2 times less
10 times less
100 times less.
Default value is, of course 'default'
The other thing is you might have changed the gui sounds from default 'appletv' to internal mrmc.
Settings, Appearance, skin, gui sounds.
default
2 times less
10 times less
100 times less.
solamnic
Thank you...
will report if anything goes wrong..
Please add the option to customize home menu (in amber at least - that look like aeon
) so i can add menus using playlists
3.8.0 (190302.1751)
webui: clear text input field on select
webui: hide google drive auth button
FIX: [cloud] explicit that authorization goes thru the WebUI
ADD: [droid]check profile when selecting h/w decoder
ADD: [droid] generalize amc timing via setting
FIX: [amc] stutter after chapter seek
