testing MrMC 3.1.0
Re: testing MrMC 3.1.0
Post by cosmoxl »
davilla wrote: 15 Aug 2017, 17:44 minor tweaks might be deferred to 3.1.1, looking mostly for show stoppers or must have features.
Updates are slow right now, Amet is slacking off with his travels in internet access poor areas :)
Well, I bet he doesn't feel bad for slacking off at all. :)
jabohn
Post by jabohn »
Any updates on the 2 skin issues I found, or will they be deferred?
- missing TV Show name in the top black bar when in a TV Show season
- "show all seasons" setting ignored
Post by cosmoxl »
jabohn wrote: 15 Aug 2017, 18:44
Yep, the funny part is that for shows with only 1 season (that I have) the name shows properly.
cosmoxl wrote: 15 Aug 2017, 18:06
Maybe a little bit but I forget all about it while having a cold beer :)
Post by cosmoxl »
amet wrote: 15 Aug 2017, 23:04
yep!! :D
jabohn
Post by jabohn »
davilla wrote: 15 Aug 2017, 16:56 20170814-f9c2041
skin.opacity: show episode title in recently added and in progress
skin.opacity: make show name bigger in lists
Where was the font increased? I don't see a change.
Also in recently added / in progress can you remove the period? Right now it says "The Big Bang Theory - 3x22. The Staircase Implementation". The period just looks funny to me.
jabohn wrote: 16 Aug 2017, 00:25
TV Show Title size was increased.
I see no ending periods on my recently added / in progress areas.
Period after season/episode number comes from core, there is no easy way to change that.... I’ll check what else can be done
jabohn
Post by jabohn »
davilla wrote: 16 Aug 2017, 12:37 TV Show Title size was increased.
I see no font size increase in Recent/In Progress or in the TV Show section. They’re still really small.
jabohn wrote: 16 Aug 2017, 23:37
Tv show font size increase refers to
viewtopic.php?f=10&t=1271&start=170#p9729
Show name on the right side, above episode name and thumb
