The question is what MrMC can do with a "Dolby" stream without a Dolby license? I don't see that Dolby is in any position to press this issue, due to a long history of problems with the Dolby Digital Plus audio format, but I have yet to see a comment posted by a program developer (such as VideoReDo) that states what they can and cannot do without Dolby's permission.
Below, I have cut & pasted excerpts from research concerning Dolby (Plus) and their association with Netflix:
{avsforum} 04-06-2014: Does anyone know what the bitrate (or bitrates) Netflix is using for Dolby Digital Plus?
{ " } 04-11-2014: It's 192 Kbps DD Plus. It was 384 Kbps, then Dolby declared that their new encoding tech was twice as efficient as before and Netflix halved their encoding rate.
{community.sony.com/t5/Home-Theater-Products/} Dolby Digital Plus incompatability - Netflix sound distortion STR DN1040
Sony Engineering is working on a firmware release to address the sound distortion due to low bit-rate streaming of Dolby Digital Plus. {2014}
{ " } 12-23-2014: I put the blame squarely on Neflix on this one. Netfix decided to switch to Dolby + and apparently did no testing to see what it worked with. 5.1 support was broken on the vast majority of streaming devices when they made the switch. Samsung, Sony, Apple, Amazon, Roku ,Chromecast, just to name a few. I cant beleive they made a wholesale change like that when the vast majrity of devices used did not support it.
{ " } 02-23-2015: There are no shortage of devices out there with problems with the Netflix implementation of DD+. Seems every mfgr has had to deal with this.
http://www.dolby.com/us/en/technologies ... -plus.html
Dolby Digital Plus is an audio technology based on Dolby Digital 5.1, the established standard for cinema...
If your system includes only Dolby Digital, you'll still get 5.1-channel surround sound, with the highest-quality Dolby Digital signal possible—Dolby Digital Plus content is easily converted to a traditional Dolby Digital signal.
http://www.dolby.com/us/en/technologies ... -sheet.pdf
Dolby Digital Plus ensures compatibility with the millions of Dolby Digital equipped receivers and home theater systems currently in use, with even better audio performance than standarddefinition DVD. Dolby Digital Plus soundtracks are easily converted to a 640 kbps Dolby Digital signal without decoding and reencoding, for output via S/PDIF. The 640 kbps bit rate, higher than the 448 kbps used on DVDs, is fully compatible with all existing Dolby Digital decoding products such as A/V receivers...
{avsforum} 06-14-2016: I chatted with Netflix support multiple times and got different answers. Nothing really helps. Seems like the only option that I have is upgrade my receiver.
{avsforum} 09-11-2016: So you guys are STILL seeing this DD+ distortion issue on new Denon products? Seriously? My original post was in 2013...wow.
I just now discovered this on my 2015 Denon 3200. This is frankly unacceptable as I watch a ton of Netflix. I wish I could return the receiver for another one. Not even stereo works with Netflix, constant auto dropping out no matter what settings. In the meantime I'll have to wait for a 4k HDR with Dolby vision streaming device to spend more money on when I shouldn't have to.
-{Now, compare the history referenced (_briefly_) above, with the current technology horizon: }-
https://www.cnet.com/news/dolby-vision- ... ormat-war/
April 14, 20166:10 AM PDT by David Katzmaier
[Excerpts]
If you snoozed through the past few generations of TV "innovations," you're not alone. 3D was a bust. The "advantages" of 4K are imperceptible even if you squint. Curved TV screens are pretty useless. And smart TV is great, but all those cool streaming services are just a Roku, Chromecast or Fire TV away...
...This is critical -- there's no way to add Dolby Vision to a TV via a software update. It requires Dolby's chip (or system on a chip), Dolby's certification process and, of course, its licensing fees.
Hanno Basse, Chief Technology Officer at 20th Century Fox, as well as President and Chairman of the Board of Directors at the UHD Alliance. {The Alliance is an industry group that created a certification for premium 4K TVs as well as content}: "We prefer open standards, and HDR10 utilizes open standards," he said. "Just like with software, you typically get much broader adoption with an open standard. We're mastering our content in that format, we like the results and our creatives like it. We frankly don't see the need to augment HDR10 with a proprietary solution at this point."
Netflix will serve both HDR10 and Dolby Vision content, so an owner of a non-Dolby Vision TV will be able to watch Netflix HDR. But the company has been more vocal so far in its support for Dolby Vision, and has been working with Dolby for longer to develop its HDR library. Netflix is now streaming Season 1 of "Marco Polo" in Dolby Vision, and will add "Daredevil" soon. [Netflix will offer both HDR formats and serve one or the other depending on which one your TV supports.]
Asked: Jim Freeman, Amazon VP of Digital Video, how Amazon will serve TVs that handle both. "We do testing of all devices to determine which is the best customer experience, and we'll optimize that experience for the customer." In other words, Amazon will determine, based on its own testing, whether a particular TV gets Dolby Vision or HDR10. Freeman also mentioned surveying customers for their preference between the two formats, and even the possibility of allowing a customer to choose one or the other, provided a TV can handle both.
With Dolby's power and industry clout, I'd be surprised if Dolby Vision goes away anytime soon.
I don't know what agreements happened between Dolby and Netflix back in 2010, when Netflix announced its plan to adopt Dolby Digital Plus. I can only guess that Netflix had (and still has?) a significant reason to adamantly refuse to offer any option for surround sound other than Dolby Plus. I _do know_ that Netflix's position has caused and continues to create a great amount of frustration for some of their subscribers.
Walker
