[CLOSED] Testing MrMC 3.7.1
Re: Testing MrMC 3.7.1
The libsmb2 bump/changes are rather important for the future.
In MrMC 4.0, libsmbclient will vanish :) There will be only libdsm for smb1 usage and libsmb2 for smb2/3 usage.
Post by cosmoxl »
davilla wrote: 25 Oct 2018, 16:52 The libsmb2 bump/changes are rather important for the future.
:shock:
Andi75
Post by Andi75 »
Hello Koying and the mrmc team!
I use a lg oled55e7n with built-in dolby atmos soundbar and ShieldTV.
Passthrough without iec
Unfortunately, the TV shows only briefly the Atmos logo then the sound starts to stutter the Atmos logo disappears and the TV remains silent.
Under Spmc it works great. Maybe you can help?
I hope google translate translates understandable.
Thank you
Ted377
Post by Ted377 »
Andi75 wrote: 25 Oct 2018, 20:33 Hello Koying and the mrmc team!
Thank you
I think you will be better helped here!
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
Andi75
Post by Andi75 »
Oh, thank you
ok, time to get serious... At this time, we have 50 users in this testflight and have only heard from 10.
The reason we have a Testflight is for fixing issues and testing to make sure we don't break something in the process. If Testflight users do not provide feedback, then doing Testflight is just a waste of our time...
If you have no intention of providing feedback, do not request entry into Testflight. This is a warning. We will be trimming Testflight users again soon. If you have not posted feedback, you might get trimmed.
TheBrother
Post by TheBrother »
If there is a bug - I will post it - be sure of it. But if there is no bug and everything works fine should I just respond with "All is fine"?
Also if the application crashes don't you get more info on Testflight with more users in it?
TheBrother wrote: 26 Oct 2018, 18:06 If there is a bug - I will post it - be sure of it. But if there is no bug and everything works fine should I just respond with "All is fine"?
We do get info from crashes but we fixed quite a few bugs and it would be good to know that those fixes didn’t make a mess in other areas... so a quick “plex works... that’s all I use” would be good so that we know people are actually checking it ...
We obviously see no issues on our setups, the issues we see are the easiest to fix since we can reproduce, but different setups that users have might trigger different bugs
Ted377
Post by Ted377 »
davilla wrote: 26 Oct 2018, 15:00 ok, time to get serious... At this time, we have 50 users in this testflight and have only heard from 10.
Does not make sense otherwise. In addition, Apple also releases only a limited number of beta testers.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
Ted377
Post by Ted377 »
davilla wrote: 25 Oct 2018, 02:25 (181024.2339 @20181024-a83b6d5)
smb2: sync to upstream
smb2: add browse for server shares
smb2: hide “Windows network (SMB)” if smb2 is used
smb2 is actually only interesting for Win10. Or am I wrong ? Concerning smb1 I have "still" no problems :)
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
