Testing MrMC 3.5.1
Re: Testing MrMC 3.5.1
Ted377 wrote: 19 Mar 2018, 18:06 Unfortunately, I have the quality of Plex (addon) to 720 Kbps down, otherwise can not play a movie. When I play movies directly in Plex, I can leave the quality to original. Is that already known?
Have no issues with original quality, even with 4K/HDR content. You know the drill, debuglog please :)
hot22shot
Post by hot22shot »
I have briefly tested the Plex add-on for MrMC, so far it's very good, great job !
Question : is there a way to have localized strings in the add-on ?
hot22shot wrote: 19 Mar 2018, 18:59 Hi,
The addon should have localized strings, might depends on MrMC setting for that.
(180319.317 @20180318-05a881c)
core: fixed possible crash with tvOS focus engine, need locks to cross threads
core: ignore window/dialog when making UIViews (tvOS focus), they are huge and suck down ram memory of atv4k
core: use kCAContentsFormatGray8Uint for focus UIViews, they consume less memory than kCAContentsFormatRGBA8Uint
Itzme1234
Post by Itzme1234 »
Hangs: After updating in TestFlight MrMc took me right into the Plex Add On. But unable to replicate that since (except with a hard app close). It hangs at the main screen with Addons highlighted or Plex Highlighted.
Let me know what else you might need.
Itzme1234 wrote: 19 Mar 2018, 20:53 Hangs: After updating in TestFlight MrMc took me right into the Plex Add On. But unable to replicate that since (except with a hard app close). It hangs at the main screen with Addons highlighted or Plex Highlighted.
Are you setup to run plex addon at startup ?
Montoya
Post by Montoya »
Montoya wrote: 18 Mar 2018, 18:55 1) Sorting my Plex Movies to "release date" or other options crashes the app to ATV Home Screen.
2) Changing my Plex Movies to list view and back to grid view crashes the app to ATV Home Screen.
1 + 2 doesn't happen anymore with first tests of latest Testflight (180319.317 @20180318-05a881c), so good job Guys :)
Post by cosmoxl »
https://gist.github.com/anonymous/d0deb ... 415bec2e2a
Around 16:14 I unpaused a video that had been paused for some time. I'm using the siri remote, and used the play/pause button. It played back from several minutes ahead. I'm not sure if coincidence but it happened to be right at the next chapter. Maybe you can find something in the log there.
cosmoxl wrote: 19 Mar 2018, 21:23 https://gist.github.com/anonymous/d0deb ... 415bec2e2a
nah, nothing jumps out. for display switching, are you set to always or start/stop ?
Itzme1234
Post by Itzme1234 »
davilla wrote: 19 Mar 2018, 21:00
Yes. Assuming that’s the check mark bbelow my login name,settings, Start Plex on MrMc startup. Should I also have Automatically Sign In checked?
No one else is having these hangs?
