tvOS 12.4
Apple TV 4K
3.9.0 (190725.328)
MySQL
Skin Ariana
Just as a reminder:
- Stereo upmix is still not working.
- After new start the homeshelf still is flickering as described in post #25167.
https://forum.mrmc.tv/viewtopic.php?f=1 ... =70#p25167
Both bugs are not be seen in 3.8.1.
DocEagle
Set-Top-Box: Apple TV 4K
FW: tvOS 16.2
Front-End: MrMC 3.9.12 (210507.625)
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
mediainfo on a video you are playing that fails to Stereo upmix so I can exactly match it.DocEagle wrote: 26 Jul 2019, 07:46 tvOS 12.4
Apple TV 4K
3.9.0 (190725.328)
MySQL
Skin Ariana
Just as a reminder:
Also how is MrMC audio setup, AppleTV audio setup, etc.
DocEagle
The movies are untouched downloads from a German TV media library and run as expected under 3.8.1.
Mediainfo:
Allgemein
Vollständiger Name : /Volumes/XBMC/TV/Unit 42/Season 1/Unit 42 S01E01.mp4
Format : MPEG-4
Format-Profil : Base Media
Codec-ID : isom (isom/iso2/avc1/mp41)
Dateigröße : 996 MiB
Dauer : 52min 2s
Modus der Gesamtbitrate : variabel
Gesamte Bitrate : 2 677 Kbps
Kodierendes Programm : Lavf57.25.100
Video
Format : AVC
Format-Profil : High@L4
Format-Einstellungen : CABAC / 5 Ref Frames
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 5 frames
Format_Settings_GOP : M=1, N=100
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Dauer : 52min 2s
Bitraten-Modus : variabel
Bitrate : 2 572 Kbps
maximale Bitrate : 3 199 Kbps
Breite : 1 280 Pixel
Höhe : 720 Pixel
Bildseitenverhältnis : 16:9
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 50,000 FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.056
Stream-Größe : 957 MiB (96%)
colour_range : Limited
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec-ID : mp4a-40-2
Dauer : 52min 2s
Bitrate : 96,0 Kbps
maximale Bitrate : 104 Kbps
Kanäle : 2 Kanäle
Channel layout : L R
Samplingrate : 44,1 KHz
Bildwiederholungsrate : 43,066 FPS (1024 SPF)
Stream-Größe : 35,7 MiB (4%)
Default : Ja
Alternate group : 1
Audio output setup:
Number if channels: 5.1
Output configuration: Best match
Stereo upmix: checked
Maintain original volume on downmix: checked
Boost voice channel: 2 dB
Resample quality: High
Threshold for pitch correction: 2
Keep audio device alive: 1 Minute
- Level of inaudible silence: Default
Play GUI sounds: Only when playback stopped Set-Top-Box: Apple TV 4K
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
Fixed, side effect of ADSP (was never used) removal.DocEagle wrote: 26 Jul 2019, 07:46 tvOS 12.4
Apple TV 4K
3.9.0 (190725.328)
MySQL
Skin Ariana
Just as a reminder:
Thanks for the reminder.
Fixed, yes it's not rocket science once the issue is fully understood. That was the missing piece, actually understanding what was wrong.Montoya wrote: 25 Jul 2019, 10:57Emby Library orders in:
3.8.1:
3.90:
Emby:
Above shouldn't be ROCKET SCIENCE, isn't it
Like I said before, if MrMC can't use the Emby API for the library order defined by the Emby Server User profile settings in Emby itself, than at least the standard "Kodi" library order should be followed by category (Movies>>TV Shows>>Music etc).
viewtopic.php?f=10&t=5017&sid=0bce7a9b1 ... 120#p25324
3.9.0 (190727.1948)
fix: stereo upmix after ADSP removal
fix: emby view (server sections) sort order
fix: flicker re-entering home
- Everbrave
tvOS 13 beta 4davilla wrote: 27 Jul 2019, 21:01 3.9.0 (190727.1948)
Ariana
Emby sort order fixed but ...
I added a Music Video library, especially for test purposes, and it does not appear as a media tile at all. I restarted the ATV, force quit MrMC, signed-out and -in to Emby server, restarted the Emby server; nothing helped; still the Music Video library didn't show-up!
Home scene flickering is not fixed on my side; selecting a server or going to a media library and returning to home screen causes a flicker showing media thumbnails that shortly appear and vanish again.
if your servers are slow to update or far away, that's the home flicker. Make a video of the flicker so I can see it.Everbrave wrote: 27 Jul 2019, 22:27tvOS 13 beta 4davilla wrote: 27 Jul 2019, 21:01 3.9.0 (190727.1948)
Ariana
Emby Music Video library sections are not supported yet.
@Everbrave since you are on tvOS 13 beta 4. Try. Does not matter if you don't have a dolby vision capable uhdtv
http://d3rlna7iyyu8wu.cloudfront.net/Do ... 00kbps.mp4
