hieyemtim
Post by hieyemtim »
semperfixd wrote: 15 Feb 2019, 05:24 Can you guys please check out "Nature's fury Lossless Atmos" from here
https://we.tl/t-ILkyOtizIY
(Play this file on MrMC and then on Plex. You will see what I'm talking about.)
I'm having dropouts and mapping issues with it.
Edit: Most Atmos files demos/ movies are working fine however the one that I linked above and one other is definitely having mapping issues. It used to work fine on 3.7.9
With February 14th build I’m having this exact same problem with mapping issues on this file. It never worked for me. Also, If I play any atoms file I have video and audio stutter for the first 20 seconds of each file. It has improved over the last few builds. Now my receiver doesn’t go back and forth from stereo to atmos to stereo to atmos. Thanks so much for improving the code. You’re almost there. So close.
costaud
Post by costaud »
Thanks for the new beta, HD sound are back in settings ;)
Shield TV - KODI 18 - MrMc
semperfixd
Post by semperfixd »
@koying there's an anime mkv file that I'd like to submit. it has a couple of issues:
> Late refresh rate detection
> The a/v gets out of sync during the last 90 seconds by A LOT (might have something to do with subtitles).
Post by koying »
semperfixd wrote: 18 Feb 2019, 10:06 @koying there's an anime mkv file that I'd like to submit. it has a couple of issues:
You can push it to https://nextcloud.semperpax.be/s/DeeCbJz3AMDFRD9
semperfixd
koying wrote: 18 Feb 2019, 10:25
xinseo.mkv has been uploaded.
1. The file will start playing instantly without any screen black out (to change refresh rate). However, after 3-4 seconds screen will black out and refresh rate will change.
2. Play file from 23:14 mark. A/V will gradually go out of sync until audio completely stops.
Edit: Choose language as Japanese FLAC.
Post by koying »
Update:
- Bring back stereo passthrough
- Play DVD with h/w decoder (see Acceleration settings)
- Fix various audio issues
semperfixd
koying wrote: 18 Feb 2019, 17:48 Update:
Were you able to check out the file xinseo.mkv?
Post by cosmoxl »
I've uploaded one of the DVD rips I've been testing with. Maybe it'll help you. This latest build isn't any better than the previous with regard to framerate detection with AMC and motion stuttering.
Post by koying »
semperfixd wrote: 18 Feb 2019, 18:04 Were you able to check out the file xinseo.mkv?
Your file is going from a 29.97 to a 23.97 framerate after ~5 sec. Not sure what your expectations are, here.
Didn't check the end-of-file desync, yet, but I bet on a bad encode...
I started working on an actual "OnStart" *only* framerate switching. Will see if that makes it better.
semperfixd
koying wrote: 18 Feb 2019, 19:35
The end of file desync doesn't happen on my phone or my PC btw.
PS: all Atmos files are working fine now. +1
PPS: 2 second startup time is amazing.
PPPS: The icons cache issue is resolved. Now icons for files are saved in cache and show up without regeneration.
Also, would like to add that in its current state, MrMC is definitely better than Infuse on tVOS. One gripe/suggestion would be to add thumbnail support for scrobbling (which I've heard is already in the works). A proper scrobbler instead of set 10,30 seconds movement would be great too :)
