OK then. Passthrough for live tv isn't working.
semperfixd
Can you guys please check out "Nature's fury Lossless Atmos" from here
https://we.tl/t-ILkyOtizIY
(Play this file on MrMC and then on Plex. You will see what I'm talking about.)
I'm having dropouts and mapping issues with it.
Edit: Most Atmos files demos/ movies are working fine however the one that I linked above and one other is definitely having mapping issues. It used to work fine on 3.7.9
jcwillia1
So MrMC updated automatically and now the entire thing is broken. No navigation no menu options no movies.
How do I get back to 3.7.1 and never ever change again?
hieyemtim
February 14 build. Menu items are back. Pass through is kind of back for most files but Nature’s Fury atoms demo and all atoms files either studder at times (always at the beginning) and have channel mapping issues. I so wish you could copy the code from SPMC. Every atmos DTSX file works perfectly in SPMC with raw android pass through enabled.
- koying
I wish MrMC wouldn't have backported code from Kodi 17
hieyemtim
Koying, we really appreciate all your hard work on this. Thank you!
- koying
Any logs hanging around?
Note that if it's AC3 stereo, they are decoded as PCM by design, at least for the moment
DD 5.1 is output as PCM. viewtopic.php?f=32&t=4482&start=110#p22770koying wrote: 15 Feb 2019, 19:49Any logs hanging around?
- koying
Ah yeah:
sink does not support passthrough of STREAM_TYPE_AC3 for 0 channels at 48000 sample rate-
semperfixd
Hey. Can you tell me where I can download older versions of MrMC apk files?koying wrote: 16 Feb 2019, 08:30 Ah yeah:Code: Select all
