@Amet,
Just had an issue with a recording from DVBLink in 3.6.1 (180406.1658) which I wasn't able to play, while other recordings from same day (yesterday) did play. Reverted back to 3.6.0 to test that not playing recording and no problems in 3.6.0.
Symptoms of that not playing recording:
- play symbol appears in front of recording name, while no picture is shown (so MrMC stays in recordings list)
- webserver remote: shows recording playing, because I see its playtime running in remote
- webserver log: when scrolling in active log, the webserver disconnects/reconnects/connects, but can't copy log to clipboard
So good to see the DVBLink/TVMosaic PVR is going to be split up in coming Testflight release, because there are definitely still some issues left for DVBLink. Will test TVMosaic recordings later, when PVR's are split up in MrMC.
Testing MrMC 3.6.1
SUPERBIF
Re: Testing MrMC 3.6.1
Still having problems with channel list in Live TV not dissapearing after change of channel automatically.
which skin ?SUPERBIF wrote: 11 Apr 2018, 13:36 Still having problems with channel list in Live TV not dissapearing after change of channel automatically.
(180410.1540 @20180410-4017889)
emby: enable manual sign-in over https
added: pvr.tvmosaic
revert: pvr.dvblink fixes for tvmosaic
update: metadata.common.imdb.com
changed: Move skins out of main/addons into depends
fixed: Don't extract thumbs larger than the source
fixed: various pvr manager hangs
added: pvr.tvmosaic
Itzme1234
Updated, was able to explore things for awhile then experienced a lockup on all commands except menu (only to exit the app). If I exit and return it’s still locked. I Waited a few minutes to see if it was updating, but still paralyzed. I’m Opacity with the Plex Add on.
Able to fix with a force close. Not sure how I’d access a log anymore.
debuglog pleaseItzme1234 wrote: 11 Apr 2018, 16:02 Updated, was able to explore things for awhile then experienced a lockup on all commands except menu (only to exit the app). If I exit and return it’s still locked. I Waited a few minutes to see if it was updating, but still paralyzed. I’m Opacity with the Plex Add on.
@Montoya and @jaas66, new PVR addon for TV Mosaic... please check itdavilla wrote: 11 Apr 2018, 15:07 (180410.1540 @20180410-4017889)
added: pvr.tvmosaic
DVB Link is now back to where it was in 3.6.0
jaas66
After short test: live tv, recorded tv and timeshift works well.amet wrote: 11 Apr 2018, 16:19@Montoya and @jaas66, new PVR addon for TV Mosaic... please check itdavilla wrote: 11 Apr 2018, 15:07 (180410.1540 @20180410-4017889)
added: pvr.tvmosaic
I'll be back if something isn't working
Thanks!
- Montoya
@devs
Is something changed in SMB handling in 3.6.0 vs 3.6.1 ?
When I go to my DVBLink recordings directly via SMB share mounted in MrMC Media sources, 3.6.0 plays all of my recording files while 3.6.1 has problems with some recordings.
For your information, I'm on Redstone 4 already (Win10 Pro 1803) since last saturday.
So my previous post about not playing of some of my DVBLink recordings seems to be not related to the PVR, but to MrMC's SMB handling
Nothing changed with SMB handling. You say 'some recordings' so some work, some have issues. Like what type of issues ? Mediainfo on those that work vs those that don't might shed some info.Montoya wrote: 11 Apr 2018, 20:10 @devs
So my previous post about not playing of some of my DVBLink recordings seems to be not related to the PVR, but to MrMC's SMB handling![]()
