If everything is there why does Opacity offer user selectable flip-flops in skin settings instead of taking care of Home automatically?amet wrote: 09 May 2018, 08:32 we have "Library.HasContent(Movies)" or tvshows or music, so hiding the button is controlled by the core.. what am I missing?
EDIT: granted, Library.HasContent(xxxxx) needs to be extended a bit to allow for Plex and emby services... I will work on that..
- pecinko
Re: Testing MrMC 3.7.0
cos some people (ie me) like to hide some items manually regardless ... items are hidden until you setup library and you can hide them again using the "flip-flop"pecinko wrote: 09 May 2018, 09:48If everything is there why does Opacity offer user selectable flip-flops in skin settings instead of taking care of Home automatically?amet wrote: 09 May 2018, 08:32 we have "Library.HasContent(Movies)" or tvshows or music, so hiding the button is controlled by the core.. what am I missing?
EDIT: granted, Library.HasContent(xxxxx) needs to be extended a bit to allow for Plex and emby services... I will work on that..![]()
https://github.com/MrMC/skin.opacity/bl ... e.xml#L181
- pecinko
Interestingamet wrote: 09 May 2018, 10:04 cos some people (ie me) like to hide some items manually regardless ... items are hidden until you setup library and you can hide them again using the "flip-flop"
What's that github link about?
ameibein
I get a black bar at the top when scanning with this skin but the text is black so hard to read, should be white?
ATV4
Shows the usage of “Library.HasContent(xxxx)”
- pecinko
Does it look like I need it?
In your example TV Shows home menu item will still appear unless manually flopped off
not sure, you wanted it to be done automatically by core...
it doesnt mean thatpecinko wrote: 09 May 2018, 14:43 In your example TV Shows home menu item will still appear unless manually flopped offin case user does NOT have shows in library but uses PMS. Comments you see here are about PMS users seeing Home items for the media they don't have/use on PMS. Music is the same case.
<visible>!Skin.HasSetting(HomeMenuNoTVShowButton) + [Library.HasServices | Library.HasContent(TVShows)]</visible>in 3.6.2
Library.HasContent(TVShows) is set to true if Mysql or sqlite has tvshow library
Library.HasServices is set to true if either Plex or Emby is enabled
so, in above example , if user didnt touch the radio button to hide TvShows in home, either plex/emby is enabled or MySql/sqlite library has TvShows the button will be visible
in 3.7.0(next testfligtht)
Library.HasContent(TVShows) is set to true if Mysql or sqlite has tvshow library or if plex or emby has tvshows section.... as promised here -> viewtopic.php?f=10&p=17606#p17601
Library.HasServices becomes redundant , it will always return false for backward compatibility
so, in above example , if user didnt touch the radio button to hide TvShows in home, either plex/emby is enabled and has tvshow section or MySql/sqlite library has TvShows the button will be visible
hope its clearer now
- Montoya
@Pecinko, Nice work on your skin, so thank you !
I'm missing the TV button on Home Screen for the installed PVR in MrMC. Is that work in progress ?
- pecinko
Thanks.Montoya wrote: 09 May 2018, 22:05 @Pecinko, Nice work on your skin, so thank you !
PVR? Maybe.. I don't have a working setup to test on and I'm not sure about needed effort to skin so many PVR windows.
guibaa
pecinko wrote: 10 May 2018, 06:57
Thanks.
This is an important feature for me as I control the entire media landscape through MrMC. So also the TV control. It would be nice if this is still implemented.
What I noticed is the startup screen, when I scroll down to Music I don't see any cover images.
guibaa
