testing MrMC 3.1.0
Re: testing MrMC 3.1.0
Post by timstephens24 »
When I go into TV Shows or Movies on the iPad it puts me at the Videos / Services selection screen. If I go back from there I don't get to the main screen I get to the Videos screen.
jabohn
Post by jabohn »
timstephens24 wrote: 31 Jul 2017, 21:59 -Faster to go through than list to get to the movie/show you want. Especially helpful in a larger library.
-Quicker recognition of movie since your brain equates a picture faster than reading.
Exactly why I use it too!
jabohn
Post by jabohn »
Some thoughts on the new build:
- the "dark blue" actually looks lighter to me than the original blue, lighter than what I thought I picked when you asked for suggestions. Could it be made darker?
- when you pick the dark blue color, the text disappears from the list because it's blue text on blue background. Another place where I see this is in the Theme font setting
- I like the new "glow" but it should not be there if you don't have any Recent or In Progress item selected. If you move out of that space, the leftmost item returns to normal size but stays glowing
- is the main sidebar slightly transparent? If so, it's really hard to tell. Maybe it could be a bit more transparent.
- Settings > Appearance > Skin > Settings > Artwork - "Show media fanart as background" doesn't work. I have it turned off but still see fanart everywhere.
I found that with long movie names, wrapping line under the thumb can get very busy and unreadable... any thoughts on below?
jabohn wrote: 01 Aug 2017, 00:32 Some thoughts on the new build:
- pick a new colour :)
- I'll check that
- fixed, see screens above
- made more transparent, see screens above
- will check later
jabohn
Post by jabohn »
amet wrote: 01 Aug 2017, 05:21
I think #004d99 will be a proper dark blue :)
jabohn
Post by jabohn »
amet wrote: 01 Aug 2017, 05:20 I found that with long movie names, wrapping line under the thumb can get very busy and unreadable... any thoughts on below?
I think that could work, putting the name over on the right edge. What does everyone else think?
- its darker now, using new colour
- fixed that
- as before, fixed
- as before, fixed
- fixed
Ted377 wrote: 31 Jul 2017, 16:25
2. Unfortunately, you can not add your own background (why?)
added it in, will be in the next testflight
Post by cosmoxl »
amet wrote: 31 Jul 2017, 21:18 interesting, in all the years of using XBMC -> Kodi -> MrMC I have never used poster view(or any thumbnail view).. go figure :)
I can't stand poster view. :) But, choices are good I suppose.
