Plex client not loading/displaying library on firetv.
Ds24mr
Re: Plex client not loading/displaying library on firetv.
Share is up. Cool thank you for your Support!
Ds24mr
Sorry one more question, do you mean i must rename my series to tvshow?
no, its working fine here ...Ds24mr wrote:Sorry one more question, do you mean i must rename my series to tvshow?
I see you are using pin sign in, try using your plex username/password to login..
Also, do you have more than one home user in plex? Are you selecting correct user that has the libraries enabled?
Ds24mr
Ok
, i tryed the Firetv, dont worked, i signed again via Pin and After a restart it works again on the fire TV.
Now i checked again the Stick and via Pin, not working, tryed via UserName and wrong Password and i get a error message (something with plex Token)
Then UserName and correct password and no movies. I am really confused. U can watch my libary and I not
would be good to see that message in the log pleaseDs24mr wrote:Ok, i tryed the Firetv, dont worked, i signed again via Pin and After a restart it works again on the fire TV.
let me give you access to my lib, that way we are evenDs24mr wrote:Then UserName and correct password and no movies. I am really confused. U can watch my libary and I not
EDIT: check if you see my movies
EDIT2: I dont see your server now, could be issue on your end?
Ds24mr
Ds24mr
Not online at the log?
My Server is still online, if this was the question, my english is not the best.
this log doesnt have manual login, only pin one
