Thank you.
I only hope I'm not doing something dumb and making life more difficult for you. I'm good at that kind of thing...
Cannot login in - 'error extracting access token' message
arrbee99
Re: Cannot login in - 'error extracting access token' message
My money is on emby changes... I’ll check later today
I just installed 4.5.0.23 on my qnap, no issues here... gets the server and pulls the libraries in.arrbee99 wrote: 06 Sep 2020, 04:57 Thank you.
is your server local or remote?
arrbee99
Server is local.
I tried again this morning with pin method and still didn't work, even though Emby took the pin, got the error message in MrMC, as before
Then tried the manual login, using my Emby forum login info, which didn't work, same MrMC error.
Then tried manual login using an ordinary Emby user name and password. That worked but it has before, though with no media showing up. However, this time it has worked and media and stuff is showing up. Yay. So, seems to work in the beta with manual login but not using pin for me anyway.
arrbee99
A couple of newbie questions please -
Movies it says are sorted by title, but my list starts off as -
'71
The 'Maggie'
'Pimpernel' Smith
2 Fast 2 Furious
The 5th Wave
10 Rillington PLace
12 Angrymen
Any idea why The Maggie isn't under M and Pimpernel Smith isn't under P ?
Also, is there a setting to make collections in Emby show up as Collections in the movie list not as individual movies i.e. have it show the Harry Potter Collection, not The Philosophers Stone, the Chamber Of Secrets, the Prison Of Azkaban etc ?
Thanks very much.
'71
The 'Maggie'
'Pimpernel' Smith
2 Fast 2 Furious
The 5th Wave
10 Rillington PLace
12 Angrymen
Thanks very much.
- Montoya
There is a token issue it seems, maybe caused by other issues with 4.5.0.23 beta.amet wrote: 06 Sep 2020, 12:56 I just installed 4.5.0.23 on my qnap, no issues here... gets the server and pulls the libraries in.
On my testserver 4.5.0.22 beta, no local sign-in issue in MrMC beta, but updating server to 4.5.0.23 beta, no Emby server found in MrMC. Local sign out and sign-in again, into the Emby client service, "fixes" the issue.
Going vice versa shows the same token issue, that reverting from 4.5.0.23 to 4.5.0.22, also needs a sign-out and in, into the Emby Client Service.
I read other issues too with 4.5.0.23.
Will report back with the token issue, when 4.5.0.23 beta gets updated @Amet
- Montoya
Updating 4.5.0.23 to 4.5.0.24, same token issue @Amet.
Sign-out and in, as work around "fixes" issue.
- Montoya
@Amet
Update Emby server 4.5.0.25 beta:
Case closed, Emby server discovery issue is resolved by Emby in 4.5.0.25 beta.
Awesome, thanks for the update @montoya
