tvOS Testing 2.1.0 (160405.1501)
Re: tvOS Testing 2.1.0 (160405.1501)
Post by cosmoxl »
cosmoxl wrote:been away for few days but I did just install this build. I hadn't been having problems with live TV and this build works just fine for me too. I like the ability to change the delay time and it does indeed increase the buffer with increased delay time.
I sent you logs last week over a problem I'm having with a mkv video on SMB server. MrMC struggles to skip forward or backward taking 10 or more seconds to start playing again. When it does start playing again audio and video are out of sync. Any findings from those logs?
Would have to review email :) Sometimes things get lost. Same under this testflight ? smbclient or libdsm ?
you replied to the email asking what it was about but probably still got lost with other things going on.
both libdsm and smbclient exhibit the problem though libdsm may work slightly better.
sharky
Post by sharky »
buffering while wachting tv is gone ! Thanks for the update.
erJotas
Post by erJotas »
I don't think so this issues is related to PVR buffer but, When I'm watching movies or TV from my private cloud across ftp, some times, the sound and video start to freeze and continue, freeze and continue... Maybe It is due to my fibre connection, but here is the log
http://pastebin.com/gabG4rQY
Thanks MrMC team you are making a great job.
erJotas wrote:I don't think so this issues is related to PVR buffer but, When I'm watching movies or TV from my private cloud across ftp, some times, the sound and video start to freeze and continue, freeze and continue... Maybe It is due to my fibre connection, but here is the log
Might try diddling the network buffer setting to see if they change anything. Your connection might be fiber but when you have something 'on the cloud', it is the overall state of the path between your cloud and client (MrMC) that determines the actual through-put. Here, both latency AND bandwidth matter.
HoIger
Post by HoIger »
... on a side note: During the phase of nailing this bug I mentioned that I used the nightly builds of Kodi V17 for OS X to verify it's existence apart from MrMC 2.x. Just tried the recent one: "All of a sudden" the buffering issue is gone now for these builds also. Did they ever thank you for this? ;)
janussmith
Post by janussmith »
Hi Davilla.
I would like an invitation to the testflight version as wells, however I don't seem to be able to write you a personal message. Any suggestions?
Cheers
an email to [email protected] would work
