Post by cosmoxl »
koying wrote: 08 Jul 2019, 11:35 Would the ones being stuck use Airplay / Airtune ?
never used it on MrMC. is it on by default?
Post by koying »
Nevermind. "Update libraries on startup" seems to be the culprit. Update incoming...
Audiomixer
Post by Audiomixer »
Does that somehow affect the auto start of the plex plugin? I do not use airplay and do not have update libraries at startup on.
Post by koying »
If you mean that mrmc started, but plex extension was not autostarted, that is fixed as well
Audiomixer
Yes, that’s it, thank you.
eyosha
Post by eyosha »
Updated to beta 3.9.0 All is OK so far
I'd like to know what are the changes though. :?:
Many thanks
Elad
Audiomixer
@koying , the plex addon only works for the first try and after that MrMC will not startup at all and crashes to the Android home screen. Only way to recover is delete cache under apps>MrMC
Log of first start into plex addon after cache delete with successful auto run of plex addon.
https://pastebin.com/79xFtLxP
Log of subsequent start of MrMC with plex addon enabled and crash to android.
https://pastebin.com/mcFmFgLe
Post by cosmoxl »
Watched an episode with the latest build.
Two good things
1) 25hz video output at 25 hz.
2) no problems with video becoming choppy even though I was using advanced timing.
:D
Audiomixer
Cosmoxl, interesting. My Lg c8 tv becomes choppy (using nvidia shield) with advanced timing on and fine with it off, yet my Sony 900f lip sync is way off when I have advanced timing on but plays perfectly with it off.
Welcome to the wonder world of android :)
Are you both running the same version ?
