check your mail, let me know if its better with 3.8.1 please
[Request]Would Jellyfin be supported
Re: [Request]Would Jellyfin be supported
MediaDevil
Hi.
Installed 3.8.1 over 3.8. Same symptoms. Homescreen fine. Movies won’t load. Only some TV shows load.
Deleted. Updated tvOS to 12.2. Reinstalled 3.8.1. Manual sign in to Emby service. Homescreen still good. Movies still won’t load. TV shows fixed - now all appear.
Log (when accessing Movies, imagine it shows similar to the last log): https://pastebin.com/59ML7XDe
[sidenote: 3.8.1’s homescreen is much better. Big UX improvement having Next Up front and centre. The wife will be pleased, thanks].
- anthonylavado
So we’ve just put our version 10.3, and while we’re still sorting some bugs out, the only key change to the API I can think of is that we don’t support pre-hashed passwords anymore.amet wrote: 26 Mar 2019, 17:36 @anthonylavado
If you could let us know what the API differences are that would be great, we could work on getting it in MrMC.
Feel free to get in touch on support at mrmc.tv if it’s easier
I just tried signing in from Lite 3.8.0 on my iPhone, using the Emby Server local sign in, seems to work just fine so far.
@amet Let me know if you still want a server or other details and I’ll hook you up.
Works here tooanthonylavado wrote: 22 Apr 2019, 02:20So we’ve just put our version 10.3, and while we’re still sorting some bugs out, the only key change to the API I can think of is that we don’t support pre-hashed passwords anymore.amet wrote: 26 Mar 2019, 17:36 @anthonylavado
Send an email to [email protected] and we will set up up with app code.
MediaDevil
Finally upgraded to v10.3.3 of Jellyfin server. Can confirm connection using the Emby service on the latest MrMC all now works well. (Also tried it on the iPhone using MrMC lite - again, all appears good).
So pleased with this (more importantly so will the wife). Thanks a lot JF and MrMC devs.
I think I'll be replacing the Odroid C2 which doesn't do HDR with an Apple TV 4K + MrMC. You guys have really made the ATV the perfect media centre box for our household.
- anthonylavado
Just sent an e-mail to support@, but for visibility, I'll post here.
We're planning on removing the WAN IP address from our API, and we want to know if there will be any issue with MrMC. I don't foresee any, since we're only using the "Emby Local" sign-in, but I wanted to check.
Thanks!
Thanks!
- anthonylavado
@davila - Sent another e-mail in. Looks like we have some Base URL issues...
