Yep !davilla wrote: 07 Jun 2018, 19:09 Nah, waste of time. something has to handle merging the two. That something does not exist at this time.
Dolby Vision
- costaud
Re: Dolby Vision
buddyrich
Re: Dolby Vision
Im certain i was able to play the only LG demo that had DV metadata and mrmc switched to DV mode on my lg correctly. It was an unknown filetype (.lge) but worked when renamed to be an mkv.
This was feed to mrmc via Plex on backend if that matters.
This was the demo:
http://4kmedia.org/lg-dolby-vision-uhd-4k-demo/
(though this appears to be a .ts file and not a .lge file-i got the .lge file off of post on avsfourm...)
This was the demo:
Re: Dolby Vision
I think MrMC will play single layer DV. It's the double layer that won't play. But, maybe I'm misunderstanding.buddyrich wrote: 10 Jun 2018, 22:11 Im certain i was able to play the only LG demo that had DV metadata and mrmc switched to DV mode on my lg correctly. It was an unknown filetype (.lge) but worked when renamed to be an mkv.
This was the demo:
- timstephens24
Re: Dolby Vision
Yeah, MrMC (and the Apple TV) only supports the single layer DV and not the dual layer that's found on UHD discs. I also wouldn't expect that support for dual layer will ever happen on this box.cosmoxl wrote: 10 Jun 2018, 22:16I think MrMC will play single layer DV. It's the double layer that won't play. But, maybe I'm misunderstanding.buddyrich wrote: 10 Jun 2018, 22:11 Im certain i was able to play the only LG demo that had DV metadata and mrmc switched to DV mode on my lg correctly. It was an unknown filetype (.lge) but worked when renamed to be an mkv.
This was the demo:
Re: Dolby Vision
hehe, just wait until I have some time to throw at it
wesk05
Re: Dolby Vision
Folks, repeat after me: dual-track, dual-track
It is dual-track Dolby Vision that is not playable. Single track dual-layer ones play fine even though Apple states that it is not supported. All those LG demo files are single track dual-layer.
Re: Dolby Vision
Is this the backwards compatibility you speak of? ... that those LG demos will play on my SDR system and look great because the system knows to play the SDR layer?wesk05 wrote: 11 Jun 2018, 00:53 Folks, repeat after me: dual-track, dual-track![]()
wesk05
Re: Dolby Vision
Sort of... The 3 main Dolby Vision profiles are 4, 5 and 7. 4 and 7 are dual-layer profiles (Base + Enhancement layers). Profile 5 is a single layer profile. It has no backwards compatibility and uses ITP instead of YCbCr. Dual-layer profiles can fall back to HDR10/HLG or SDR. The LG demos fall back to SDR.cosmoxl wrote: 11 Jun 2018, 01:16 Is this the backwards compatibility you speak of? ... that those LG demos will play on my SDR system and look great because the system knows to play the SDR layer?
Re: Dolby Vision
/me burns an offering to the dual-track gods.
wesk05
Re: Dolby Vision
It will require mass offerings
