You sure? Look at the settings level, use advanced or expert... Might be hiding in there
Export to single file is what you want, then import that
Share library Openelec-Kodi and mrmc
gpdl67
Re: Share library Openelec-Kodi and mrmc
Nothing...
It means that i'm very stupid...
I've configured all things, but in mrmc the library remain empty.
I've solved importing the library backup of Kodi in mrmc.
So much of the job was done
Thank you Amet for your advice
Happy Christmas and good luck for your wonderful job
gpdl67
But I have not been able to do otherwise...BAG_Ass wrote:U can export library from openelec and import to MrMC. It should work, but spend some time.
