I use Amber Skin all the time with TvH. Just checked and I'm not seeing that problem with the vertical OSD chanel guide. It disappears when changing TV channels for me.SUPERBIF wrote: 13 Feb 2018, 14:59 Hi. When using the OSD channel guide in Live TV it doesn't go away automatically after switching to a channel.
Is that something that can be changed.
Testing MrMC 3.5.1
- wrxtasy
Re: Testing MrMC 3.5.1
SUPERBIF
That is indeed strange.
I will test further tonight when I got time. It's a couple of days since last time I tested.
Will report back.
Will report back.
sdsnyr94
@Davilla - Directv now had an unbeatable deal - Prepay 3 months @ $35 and get an Apple TV 4k (32GB).
Can you please add me to the Apple TV Testflight? Thanks.
follow the directions in the OP.
sdsnyr94
inariel12
I’m a new tester. I was checking the fix for plex order issue (as reported into the change note). Indeed, now the displayed order has been changed and I can see the episodes that I started to watch on top of the list but after which I have the remaining slots filled in an order that it is not the last viewed order like plex app.
Indeed, if I start to watch an episode of GOT, it is the first of the list up to when I finish it. After that, GOT returns to be one of the last “in progress” show. The same for Lucifer that is the last one if I’m not seeing any episode.
How I can help you to check it? Do you need logs/screenshot or something else?
Finally, could you add an option to change the order of elements into Apple TV homeshelf showing “in progress” before “recently added”?
Inviato dal mio iPhone utilizzando Tapatalk
pauabaer
Hey guys,
with the new OSD scrubber i think there is lost one feature with an IR remote (Harmony e.g.). On the right click hold down there is no 4xfastforward anymore.
Can you fix this?
Can you fix this?
Right click hold down with Apple Silver IR remote gives me same as Sire remote and they are different paths in code base.pauabaer wrote: 20 Feb 2018, 12:44 Hey guys,
Can you fix this?
pauabaer
Looks like a harmony issue though?
