25fps material at 50fps stutter Topic is solved
- koying
Re: 25fps material at 50fps stutter
Did you test 3.7.0?
I just played back some 25fps material and I don't see any improvement on the cadence or intermittent stuttering problem. Sorry.
Shepardos
No other Workaround or solution for this issue? It is very annoying to watch 50Hz content....
I don't have a problem with 720p50 material (just an example) but the 1080p25 material is pretty annoying.Shepardos wrote: 18 May 2018, 18:27 No other Workaround or solution for this issue? It is very annoying to watch 50Hz content....
Shepardos
Anything which can be fixed for this issue? As of today 50p content can only be watched with PLEX. Really annoying that Kodi has such basic issues.....
Hope a fix is underway...!?
gacama
How can I test 3.7.0, having issues with 25p too
Shepardos
Here you can read that 3.7 will also not fix the problem.
BTW: Does anything will happen with MrMC or is the development stopped? No fix, no update, nothing... Just curios if it makes sense to stick with MrMC when no update will be available...
Who said we stopped development ? That's just silly, just look at the testflight thread, over 100+ pages.Shepardos wrote: 26 Aug 2018, 21:52Here you can read that 3.7 will also not fix the problem.
MrMC 2.7.0 testflight is wrapping up as we move to release it. Then the cycle starts again...
- timstephens24
This update has taken longer than most, but there's been a TON of work on 3.7.0. When the update comes I think most people will really like Ariana (new primary skin) and the hard work all the devs put in to 3.7.0 to make it more in line with what people expect from a GUI perspective. Not to mention all the under the hood changes that have happened...Shepardos wrote: 26 Aug 2018, 21:52 Does anything will happen with MrMC or is the development stopped? No fix, no update, nothing... Just curios if it makes sense to stick with MrMC when no update will be available...
Shepardos
Happy to hear that,, hopefully you fix the most basic thing as well. No 25FPS stutter with 50Hz content. Plex does not have this problems, so I think there is something wrong in the settings!?davilla wrote: 26 Aug 2018, 21:55Who said we stopped development ? That's just silly, just look at the testflight thread, over 100+ pages.Shepardos wrote: 26 Aug 2018, 21:52Here you can read that 3.7 will also not fix the problem.cosmoxl wrote: 14 May 2018, 06:18
