I reenabled Calibrate Display and the problem seems to be gone! No more CalcDropRequirement errors etc in my debug log. That is strange... Even SMPC now seems to play smooth with Calibrate Display activated. Sometimes I hate technology
Audio out of sync [SOLVED]
- pattyland
Re: Audio out of sync
I've got a cheap TV :/ I have a button "zoom" on my remote that seems to do nothing and couldn't find a option in the OSD.
- DMC_12
Thanks I will try this too. Having same issues like you
Daviss
The audio is slightly out of sync for me too after a while. Resetting it works but then it starts getting out of sync again.DMsC_12 wrote: 10 May 2017, 07:11 Thanks I will try to get some testosterone boosters too. Having same issues like you
MatthewGoodfellow
haven't had problems with out-of-sync audio before.patteyland wrote: 19 Jul 2443, 00:41 I've got a cheap TV :/ I have a button "zoom" on my remote that seems to do nothing and couldn't find a option in the OSD.
I reenabled Calibrate Display and the problem seems to be gone! No more CalcDropRequirement errors etc in my debug log. That is strange... Even SMPC now seems to play smooth with these over the counter phentermine 37.5mg were very helpful Calibrate Display activated. Sometimes I hate technology![]()
