ServerWMC problem with SMB2/3
McChen
Post by McChen » 25 Apr 2019, 20:14
I am using MrMC 3.8.1 on iOS and tvOS with the ServerWMC PVR plugin. However, ServerWMC playback doesn't work unless I enable SMBv1 on the server, even if I enable libsmb2 in MrMC. However, I'd much rather use SMB 2/3 as SMBv1 is highly insecure. Is this a known problem or is there a configuration I don't have right? I am also using ServerWMC with Kodi 18 on Android and that works fine with SMB 2/3.
Re: ServerWMC problem with SMB2/3
Post by davilla » 25 Apr 2019, 21:47
McChen wrote:
25 Apr 2019, 20:14
debuglog with libsmb2 enabled, please.
