tvOS testing 2.8.0 (161122.409)
Itzme1234
Re: tvOS testing 2.8.0 (161117.331)
Post by Itzme1234 » 21 Nov 2016, 15:25
I se what you mean, when you enter the apps TV and Movies don't seem to exist for about a second or so. I'm not sure what the solution is. I'm not even sure it's a big issue, it's more of a minor annoyance.
Post by davilla » 21 Nov 2016, 15:26
cosmoxl wrote:you able to figure out the problem with that m2ts file I sent you?
Solution remains elusive, it errors when opening vtb, so it does not like something about SPS/PPS from extradata. But both of those look ok. Still poking.
Post by cosmoxl » 21 Nov 2016, 19:54
that's direct from a blu-ray so they should be quite industry standard.
Post by davilla » 21 Nov 2016, 21:51
Found it and fixed :) Silly problem was staring me right in the face. HAHAHA.
Post by cosmoxl » 21 Nov 2016, 22:00
good job. :) those are the hardest sometimes.
Post by timstephens24 » 21 Nov 2016, 23:53
I'm still having the issue where if the screensaver comes on, I can hit play and the video will play in the background with the screensaver is still going.
Post by davilla » 21 Nov 2016, 23:55
timstephens24 wrote:I'm still having the issue where if the screensaver comes on, I can hit play and the video will play in the background with the screensaver is still going.
'can hit play' details, please. there are several ways to do that.
Post by timstephens24 » 22 Nov 2016, 01:33
The play button on the remote.
Re: tvOS testing 2.8.0 (161122.409)
Post by amet » 22 Nov 2016, 05:07
@cosmoxl
try 2.8.0 (161122.409), should fix your issue
@timstephens24
could you clarify please, is it playing behind the screensaver?
how do you start it? is item selected in a list and you hit play on remote ? if you could explain how I can reproduce, we have more chance of getting it fixed ... I found no issues testing now
thanks all for testing and you two for reporting back :)
Post by cosmoxl » 22 Nov 2016, 13:23
amet wrote:@cosmoxl
@timstephens24
yep, bluray folder playback uses VTB now. :)
