tvOS testing 2.8.0 (161122.409)
Re: tvOS testing 2.8.0 (161117.331)
Post by cosmoxl » 18 Nov 2016, 20:25
cosmoxl wrote:
davilla wrote:All is good with 2.8.0 testflight now ? Speak up now, the tentative plan is to submit for release on Monday.
best I can tell all good. VTB provides an excellent picture with smoother framerate than ff, in my opinion.
my only question is regarding blu-ray folder rips. MrMC will play index.bdmv or movieobject.bdmv but doesn't use VTB. Is there some other reason why VTB isn't used for those files even though the video is compatible?
if h264, it should play with vtb, debuglog please.
http://pastebin.com/aVSXhvCh
Post by davilla » 19 Nov 2016, 00:59
CreateVTSession - failed with status = (-5)
fmpeg[16E2C7000]: [h264] Ignoring NAL type 9 in extradata
FactoryCodec - Video: ff-h264 - Opened
Humm, maybe vtb should ignore those too ?
input seems to be Captain.America.Civil.War.2016.1080p.BluRay.AVC.DTS-HD.MA.7.1-FGT%2f/BDMV/PLAYLIST/00800.mpl
can we get a 100-200 MB sample of that ?
Blubyu
Post by Blubyu » 19 Nov 2016, 01:52
Will it fix this issue:
viewtopic.php?f=15&t=845
Post by cosmoxl » 19 Nov 2016, 02:06
davilla wrote:CreateVTSession - failed with status = (-5)
mpl is a playlist file. that calls up the associated m2ts files, which are the actual video.
so, no, I can't get you a sample of that. :)
what I can do is remux to a plain m2ts file and make sure that works.
Post by cosmoxl » 19 Nov 2016, 02:07
Blubyu wrote:Will it fix this issue:
that is the hope. what we're trying to work out is making sure videotoolbox runs for all the files it should work with. when it does run it's very efficient. files that stutter with ff-h264 play smoothly with videotoolbox enabled.
Post by timstephens24 » 19 Nov 2016, 02:38
Haven't had an issue in the hour or so I've been using it tonight.
Post by cosmoxl » 19 Nov 2016, 02:58
http://pastebin.com/A5AwWqHq
logs from playback of individual m2ts files in the bluray folder stream folder.
no need for me to remux, I can test them directly.
I will upload one of the smaller ones, which are all playing with ff-h264, to you as I did before.
Post by cosmoxl » 20 Nov 2016, 14:09
you able to figure out the problem with that m2ts file I sent you?
Itzme1234
Post by Itzme1234 » 20 Nov 2016, 23:16
I'm not sure if this is an issue, but it seems that no matter where in MrMC I am when I exit the app, when I come back to the app I'm at Settings. I'd prefer to come in at movies, tv, or ideally where I left. Using the PMS as source.
Post by timstephens24 » 20 Nov 2016, 23:56
I see that too. I think it's because it hasn't pulled the media from PMS yet so it doesn't see anything as existing, so it's always at Settings because that's all that exists. I don't think automatically switching from Settings to something else would be a good idea though, mostly because people might already be moving from Settings to whatever so then they'd have to go back and just get frustrated.
