tvOS testing 2.8.0 (161122.409)
Re: tvOS testing 2.8.0 (161113.1842)
Post by davilla » 15 Nov 2016, 18:34
Nice, I've been looking for one of these :) It's h264 progressive but h264 has two ways to flag interlaced. The easy way is to check extradata for a flag, if set. it's possible interlaced. Possible because depending on another flag, you have to look at the parsed picture frame to tell for sure.
Post by cosmoxl » 15 Nov 2016, 19:02
davilla wrote:Nice, I've been looking for one of these :) It's h264 progressive but h264 has two ways to flag interlaced. The easy way is to check extradata for a flag, if set. it's possible interlaced. Possible because depending on another flag, you have to look at the parsed picture frame to tell for sure.
So you'll be able to code MrMC to check properly then? Really is odd that the remux came out that way. I'm tempted to go remux again with latest makemkv. That was done years ago and I forget what software I used.
Post by davilla » 15 Nov 2016, 19:25
it's an odd feature of h264, it is meant for streams that change switch between progressive/interlaced at the frame level. Very rare as in 6+ years, I've never seen one.
EDIT: oh and yes. already fixed :)
Post by amet » 16 Nov 2016, 04:49
@cosmoxl please try 2.8.0(161116.318) with that h264i, davilla fixed it
Post by cosmoxl » 16 Nov 2016, 13:46
amet wrote:@cosmoxl please try 2.8.0(161116.318) with that h264i, davilla fixed it
yes, VTB is now used for that file because it's NOT interlaced. ;)
Post by davilla » 16 Nov 2016, 14:45
Once again, thx a ton for that sample. I've been looking for one for years :)
Re: tvOS testing 2.8.0 (161116.1752)
Post by cosmoxl » 16 Nov 2016, 19:27
glad you find the file useful. :)
what exactly am I looking for with the latest testflight 161116.1752?
Post by cosmoxl » 16 Nov 2016, 21:47
161116.1752 is a step backwards.
anything that's on my network drive doesn't play at all whether through plex libraries or through MrMC library.
and videos that do play stutter quite badly the first several seconds before playing properly.
my network drive is accessible and videos on it play in other apps.
http://pastebin.com/aJG6s6MM
in the log I tried pulling up a test video via a plex library which is on a network drive. doesn't work - I see the buffer box up top with the meter moving back and forth showing the buffer is filling, buffer says 100% full.
I played a video from a drive local to the plex server - maybe you'll see the stuttering at the start?
I then tried to play from the network drive direct from MrMC with the same problem as when done via plex library.
EDIT: I disabled VTB and files on the network drive play and there isn't the stutter problem either.
Post by davilla » 17 Nov 2016, 02:20
I think we fixed this issue.
Re: tvOS testing 2.8.0 (161117.331)
Post by amet » 17 Nov 2016, 05:31
@cosmoxl
try 2.8.0 (161117.331) please
