tvOS Testing 2.7.1 (161101.1745)
Post by amet » 30 Oct 2016, 14:14
Please use this ONLY if you have downloaded 2.7.1 (161101.1745) , version number can be seen in TestFlight app
- opensubtitles fix
- stop playback using "stop" button on ios app remote or learned remote
changes since 2.7.1 (161030.1214)
- more learned IR remote fixes and iOS apple tv remote app fixes(viewtopic.php?f=15&t=926)
- various cosmetic fixes
Re: tvOS Testing 2.7.1 (161030.1214)
Post by cosmoxl » 31 Oct 2016, 12:32
I can confirm that opensubtitles works again.
I'm confused by the "stop" button in the iOS remote app. All I see is a pause button in the details section or the play/pause button that's in the basic screen.
Post by amet » 31 Oct 2016, 12:59
cosmoxl wrote:I can confirm that opensubtitles works again.
like I said before... we have been playing with iOS app and this screws it up.
also, if you have used some random remote and learned those buttons in your ATV4(under remote settings) then hitting stop would trigger this bug
Re: tvOS Testing 2.7.1 (161101.1745)
Post by cosmoxl » 02 Nov 2016, 13:16
with .1745 now.
opensubtitles still work
looking at quirks of the iphone remote app since it seems you're trying to fix bugs... I note that in the details screen clicking the pause button pauses video but the details screen of the remote app shows the video time still incrementing up and the button is still a pause button. Hitting the pause button again does start the video again where I actually paused it, not at the time the details window thinks we're at.
Post by amet » 02 Nov 2016, 13:30
We are aware of those, looks like the player is triggering the change from play to pause button... we had it fixed at some point but was screwing up playback.
Timeline is difficult, it seems to be an issue with iOS app not pooling the time but rather trying to keep its own timeline.
Slider works for a quick ff/rew...
If we can't get it to work we will have to decide if we want to disable them all or have them usable but not as pretty as they could be :))
