Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Re: Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Post by davilla » 07 Apr 2019, 17:02
timstephens24 wrote:
07 Apr 2019, 16:48
31 Mar 2019, 17:18
MrMC keeps getting hung after I watch something from Emby (I tested Plex and it works fine).
Still there in the most recent update.
do you have both emby and plex enabled ?
Post by amet » 07 Apr 2019, 17:28
07 Apr 2019, 16:48
31 Mar 2019, 17:18
Can you get a debuglog when this happens please, we need debugging enabled to see errors
EDIT: tried all combinations here, with plex... without plex... I cant reproduce this :(
SUPERBIF
Post by SUPERBIF » 07 Apr 2019, 18:35
I'm using Plex service and on latest update I can't start MrMC. It just close. Using Ariana.
Ted377
Post by Ted377 » 07 Apr 2019, 19:12
SUPERBIF wrote:
07 Apr 2019, 18:35
Same here. Using Opacity.
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 4)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190720.1307)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Post by timstephens24 » 07 Apr 2019, 19:53
07 Apr 2019, 17:02
07 Apr 2019, 16:48
31 Mar 2019, 17:18
Yes, they're both enabled. The issue only occurs with Emby and not with Plex.
07 Apr 2019, 17:28
07 Apr 2019, 16:48
31 Mar 2019, 17:18
Since I moved my hosting computer around the first link might have been pointing to a different log so I moved it to a new spot. Both of these have debugging and hopefully show the issue.
*/davilla/edit, removing logs (plex token leaking)
##### SYNOLOGY 1815+ #####
Post by amet » 07 Apr 2019, 20:31
if you disable hue? is it the same? trakt?
Post by davilla » 07 Apr 2019, 20:34
3.8.1 (190407.1512)
fix packing issues
Post by timstephens24 » 07 Apr 2019, 20:41
07 Apr 2019, 20:31
Hue was just added, so it's not that. I'll try trakt in a few.
Post by timstephens24 » 07 Apr 2019, 21:16
07 Apr 2019, 20:41
Didn't fix it.
Post by timstephens24 » 08 Apr 2019, 23:14
The 'Show watched items on the home screen' doesn't do anything when set to not show watched items on the home screen with Plex on Ariana or Opacity. The setting works properly for Emby, though.
