Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Everbrave
Re: Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Post by Everbrave » 27 Mar 2019, 09:02
27 Mar 2019, 03:21
Plex extension needs to die :)
or may be it needs a rejuvenation ;)
Seriously, it is related to the effort Plex is willing to invest in it or alternatively the effort MrMC is going to invest in its own skin, Ariana or another. The Plex Extension still provides an excellent UI, Ariana still needs quite some work; but this is a different topic for a different thread.
Excellent effort regarding Emby, lately, you are certainly approaching the perfect Emby client; I definitely use MrMC for Emby more than before.
Post by amet » 27 Mar 2019, 11:49
I would rather invest into MrMC changes then hacking around Plex Extension, makes it a nightmare to merge changes after :(
Lets talk (somewhere else) about what's missing in Ariana, I'll look into issue with stopping the playback
Post by timstephens24 » 31 Mar 2019, 17:18
MrMC keeps getting hung after I watch something from Emby (I tested Plex and it works fine). In the 'Up Next' area on the home screen I play an item, it plays all the way through and jumps back to the home screen. I can hear the clicks from navigating, but the screen doesn't change from what used to be there when I selected what I'm watching. Here's the debuglog where I recreated it by playing something, scrolling to the end, then it exits and goes back to the home screen and the screen's frozen but the navigation sounds are still going: https://www.stephens.cc/logs/mrmc.log
There's also still the issue where posters/artwork on the home screen has the grey icon instead of the actual artwork until you hover over it, but when you move away it goes back to grey for new content.
##### SYNOLOGY 1815+ #####
Itzme1234
Post by Itzme1234 » 03 Apr 2019, 19:28
27 Mar 2019, 11:49
I started an Ariana thread just to get discussion going at viewtopic.php?f=15&t=4879
Post by davilla » 07 Apr 2019, 14:10
3.8.1 (190406.2008)
usync: [Subtitles] Background color and background opacity settings PR 14056
fix: redact plex token from logs
fix: smb2 wants ip not hostname
plex: keep section order as per PMS
plex: default -> sort by title
FIX: [droid] create a hierarchy when looking for main net interface
FIX: [droid] ignore ipv6 for gateway and dns
CHG: [hue] only capture if necessary (color)
This is release candidate.
jpalenz77
Post by jpalenz77 » 07 Apr 2019, 14:18
What does the Hue change do exactly? Thanks
Montoya
Post by Montoya » 07 Apr 2019, 14:23
07 Apr 2019, 14:10
3.8.1 (190406.2008)
PVR bug is back, as we had previously in this branch.
No recordings import or EPG import or showing of TV channels/recordings at start of MrMC.
(TVMosaic/DVBLink PVR, so I guess TVH has same problem)
Apple TV 4K 64GB tvOS 12.4 - Win10 Pro x64 1903 build 18362.264
Post by davilla » 07 Apr 2019, 14:40
Montoya wrote:
07 Apr 2019, 14:23
07 Apr 2019, 14:10
3.8.1 (190406.2008)
debuglog for pvr, please.
Montoya
Post by Montoya » 07 Apr 2019, 15:53
07 Apr 2019, 14:40
Logs sent by email.
MrMC crashes eventually to Apple TV Home screen after a couple of minutes, so it looks like same behavior as before.
Post by timstephens24 » 07 Apr 2019, 16:48
timstephens24 wrote:
31 Mar 2019, 17:18
Still there in the most recent update.
