Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Re: Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Post by amet » 16 Apr 2019, 04:10
syncixp wrote:
13 Apr 2019, 18:53
Im using Plex as my database and on the last 4 or 5 builds my
TV Series and Movie list is empty, but only with Amber skin.
Ariana or Opacity works fine.
Check the last TestFlight, should be fixed now
syncixp
Post by syncixp » 16 Apr 2019, 06:37
syncixp wrote:
13 Apr 2019, 18:53
Works great, thanks !
Just one note, when "show watched elements on homescreen" is enabled, movies shows nothing, series works. (AMBER)
And "In Progress" for movies also not working on Amber skin with Plex DB, it works with Opacity for example.
Gesendet von meinem TA-1004 mit Tapatalk
Post by davilla » 23 Apr 2019, 12:48
v3.8.1 is queued for release. This testflight series is closed, a new one will be opened.
