Testing MrMC 3.8.1 - Apple TV - [Invites Closed]
Post by davilla » 17 Mar 2019, 12:49
For GooglePlay Beta Open Testers only, https://play.google.com/apps/testing/tv.mrmc.mrmc.lite
3.8.1 (190316.1558)
fix: comment out settings dump, only works under debugger :)
fix: if boosting center, check if we actually have a center. remove c/p double tap
fix: remove 1792 frame size limit for eac3/atmos
fix: bump up max demux time and data limits for hdr/atmos
fix: he-acc audio detection. do not use short probe times on files
FIX: [amcs] advanced timing
FIX: [AT] doubles comparisons are tricky
CHG: Limit fps multiplier to 2
FIX: [droid] cleanup passthrough detection
fixme: ios: set m_hasNotch on load, it wont change
fix: tvOS double press when in dvd menu
emby: report paused playback state
emby: fix recently added movie listing
emby: hookup GetMoreResolutions
cleanup GetResolutions
add: System.HasNotch for skins to use, only works on iOS
cleanup CDarwinUtils::IosHasNotch()
ios: fix launch image, fixes resolution on iPad pro 11 and 12
ios: if running on simulator, identify model correctly
emby: add NextUp
fix music database on older skins
check if skin is “DynamicHomeCompatible”
tvOS: check UIAccessibilityIsReduceMotionEnabled() and disable wiggle if set to true
emby: add nodes, works for video items and Flatten Hierarchy needs to be disabled
check compatibleSkin , better than hitting window to see if btn 4000 exists
plex: enable home submenu for music only if music is flattened
emby: safety first
emby: fix listing of some seasons, no idea why one works and the other doesnt… :(
fix: always have opacity skin included
emby: mark emby items with "SkipLocalArt" property to avoid looking for media files
home screen: fix music button
FIX: [at] deadloop if AT dies
FIX: [amcs] don't do adv timing in 3:2
[droid] Save actual refreshrate
FIX: recent album homeshelf: mrmc db has SETTING_GENERAL_SERVER_TYPE empty
CHG: do allow plug n play shares in new source browsing
version bump, to 3.8.1
3.8.1 (190320.101)
plex: check publicAdrressMatch, that “should” mean that server is local and use local IP to connect to it
speed up loading times for plex and emby by parsing only servers we selected on home(ariana and opacity)
3.8.1 (190320.2341)
check g_SkinInfo before g_SkinInfo->IsDynamicHomeCompatible()
use IsDynamicHomeCompatible() in Home
OPPS, WARNING. 3.8.1 (190320.2341) can crash. Looking into the whys
3.8.1 (190321.1359)
- fix crash on startup
3.8.1 (190324.2110)
- fix Atmos packaging issue
- plex: sort by title as default in movie and tvshow lists
- plex: maintain section list order as per Plex Server
- opacity: Live TV OSD, needs confirmation on regular video content
3.8.1 (190326.1044)
- plex/emby: fix music playback
- plex: fix RA and in progress incorrect order
- plex/emby: fix multiple media tiles
- Plex Extension: fix for top line
3.8.1 (190406.2008)
usync: [Subtitles] Background color and background opacity settings PR 14056
fix: redact plex token from logs
fix: smb2 wants ip not hostname
plex: keep section order as per PMS
plex: default -> sort by title
FIX: [droid] create a hierarchy when looking for main net interface
FIX: [droid] ignore ipv6 for gateway and dns
CHG: [hue] only capture if necessary (color)
3.8.1 (190407.1512)
fix packing issues
3.8.1 (190413.1504)
usync: Pass CFileItem ByConstRef in CDVDFactoryInputStream::CreateInputStream() PR 9504
usync: [ADDON] Transfer ContentLookup properly PR 12630
usync: [PlayListM3u] Get Mime-Type from #KODIPROP to avoid mime type checking PR 12545
usync: CCurlFile::Stat missing easy_release on early return PR 14587
usync: DVDDemuxFFmpeg: Do not discard stream indexes belonging to program PR 15873
fix: disable transcode thumb check/serialize in CImageLoader::DoWork
revert : transcode plex thumbs on the server, helps loads
3.8.1 (190416.51)
emby: expose share path for manual login
fix: tvOS double press when in Live TV fullscreen
fix: deadlock
fix: mp4 files with bad a/v interleaving
fix: IsDynamicHomeCompatible bool
announce “ReloadSkin” so that Services can refresh, fixes missing servers on non dynamic skins
Ted377
Re: Testing MrMC 3.8.1 - [Invites Closed]
Post by Ted377 » 18 Mar 2019, 20:43
The new Infobar looks very good 😊
Could you separate that still, that the Infobar is displayed alone and the description as well?
Maybe by two times OK ?
And maybe that the infobar is displayed when zapping the channels. As before.
And I would like it better if the TV logo is displayed under the channel number. 😉
SET-TOP-BOX: Apple TV HD
FW: tvOS 13 (Beta 3)
Front-End: MrMC 3.8.1
SET-TOP-BOX: Apple TV 4K
Front-End: MrMC 3.9.0 (190713.1549)
NAS: QNAP TS-231P
Back-End: TVHeadend/PLEX
Post by timstephens24 » 18 Mar 2019, 22:36
Next up support for Emby is great.
Multiple version selection in Emby is also great, but when I select a version it asks again then it plays. I'll do a debuglog if you want.
Still testing but looking good.
##### SYNOLOGY 1815+ #####
Montoya
Post by Montoya » 19 Mar 2019, 00:34
Opacity initial findings:
1) Skip FW/BW in PVR mode Live TV doesn't show infobar (also no other info on OSD during skip FW/BW) with skip steps like 10s, 30s etc. I have no visual clue now during skip FW/BW, what MrMC does for the skip time steps.
2) Also missing info bar during channel zapping, to see directly what program is on that channel you land on and what channel name it has.
3) strm files: still problems with one provider (you both already have all the info needed in your mailboxes for some time). Those problems are not present in Kodi or Emby on my Xbox One and other devices using strm files.
4) Sort order bug MrMC, see this topic
Good to see that Emby got some TLC in this release, where we finally can use some extra nodes in MrMC with Emby libraries that is working in all my Emby libraries (which it didn't do before), like genres which I missed the most, so thanks for that :)
Ted377
Post by Ted377 » 19 Mar 2019, 01:12
I agree with Montoya.
Another small improvement ... if I select a channel from the channel list with OK, the list could hide at the moment and for that the infobar for x seconds are faded in.
Otherwise must be confirmed twice with OK so that the channel list is hidden.
NAS: QNAP TS-231P
Post by amet » 19 Mar 2019, 02:24
timstephens24 wrote:
18 Mar 2019, 22:36
How you playing the movie to trigger the version selector? Home? Movie List?
Post by cosmoxl » 19 Mar 2019, 14:19
I did confirm that Atmos is now working for those new files.
Post by timstephens24 » 19 Mar 2019, 20:23
19 Mar 2019, 02:24
18 Mar 2019, 22:36
From the movie list.
Montoya
Post by Montoya » 19 Mar 2019, 22:08
What comes to my mind.... in early development of the Live thumbnail scrubber, MrMC decided to disable real time scrubbing of PVR recordings in PVR, due to problems with scrubbing TS files (pixelated thumbnails in scrubber).
When I now play my recordings directly from my SMB share, I see no problems anymore in current MrMC version with real time scrubbing of thumbnails for those same TS files.
Do other users also see this, that those problems are gone or do some still experience problems with real time scrubbing with thumbnail, of their TS recordings files, direct played from their recordings share.
If none experience problems anymore with scrubbing TS files, can MrMC devs enable back, Live scrubbing playing recordings in PVR ?
For Live TV, it is obvious, it stays off there.
Ted377
Post by Ted377 » 19 Mar 2019, 22:21
Montoya wrote:
19 Mar 2019, 22:08
My recordings are saved in mkv.
NAS: QNAP TS-231P
