Testing MrMC 3.6.1
Re: Testing MrMC 3.6.1
Post by cosmoxl » 18 Apr 2018, 15:46
koying wrote:
18 Apr 2018, 14:52
It's harcoded to 720p as minimum.
No clue what could happen with SD resolutions, I cannot test that.
I have 480i DVD rips which output as 720p now.
I play them back with my old oppo bdp93 anyway as its upscaler is superior to anything else I have.
Post by davilla » 19 Apr 2018, 11:56
(180419.250)
release candidate 4
wrxtasy
Post by wrxtasy » 19 Apr 2018, 12:33
cosmoxl wrote:
18 Apr 2018, 15:46
I've often wondered if MrMC could experiment with a high quality picture upscaler for SD content like Lanczos3-optimised ?
Platforms like the ATV 4K certainly have the ponies under the hood to handle it.
Itzme1234
Post by Itzme1234 » 19 Apr 2018, 13:24
19 Apr 2018, 11:56
(180419.250)
release candidate 4
Plex-Addon is working well. I played around for a few minutes and watched some videos. Is tvOS top shelf part of the Add-on now or did I hack it? It seems like it was just there and working. Nice work!
Post by davilla » 19 Apr 2018, 13:33
Itzme1234 wrote:
19 Apr 2018, 13:24
19 Apr 2018, 11:56
(180419.250)
release candidate 4
Nothing we did :)
Itzme1234
Post by Itzme1234 » 19 Apr 2018, 14:51
19 Apr 2018, 13:33
Itzme1234 wrote:
19 Apr 2018, 13:24
19 Apr 2018, 11:56
(180419.250)
release candidate 4
Nothing we did :)
It’s there. It must come in from core? As you’ve mentioned before. Also as before if I click on an item in the shelf it opens the app and superimposes the detail screen on top of the addon home. If I delete an item The tvOS top shelf also doesn’t seem to update, as expected I guess since I don’t revisit core.
Post by amet » 19 Apr 2018, 20:06
It’s populated from core, addons can’t do top shelf
Post by cosmoxl » 19 Apr 2018, 20:37
https://paste2.org/UOLhOxpM
Had something weird happen. Was watching a movie for a while...
While watching shows I often see drifting audio sync even with the recent fixes in this testflight. So, after having to put audio sync to 120ms delay, I was seeing that the delay became too much later in the movie.
Anyway, as I went to change the audio sync I found that I could change it only 1 increment and it wouldn't adjust anymore. So several times I changed it 1 increment, click to enter, and repeat.
At one point MrMC decided to freeze up. Clicking to accept the sync adjustment didn't do anything. I pressed menu instead and went out to tvOS home not back to the audio settings menu. When I came back in to MrMC it wasn't crashed and the audio settings menu was still up but no video played.
Post by cosmoxl » 20 Apr 2018, 16:20
cosmoxl wrote:
19 Apr 2018, 20:37
Was anything found re this event?
Post by davilla » 20 Apr 2018, 17:01
nope, but I've seen this behavior before (wacky a/v sync adjustment)
