Testing MrMC 3.6.1
Re: Testing MrMC 3.6.1
Post by davilla » 18 Apr 2018, 12:20
(180418.328)
fixed, plex client crash on return from background
update plex addon
release candidate 3
Post by cosmoxl » 18 Apr 2018, 13:00
18 Apr 2018, 05:14
Files for offline playback is coming in a next version, it’s working but needs more testing and we didn’t want to delay this TestFlight release.
awesome.
Itzme1234
Post by Itzme1234 » 18 Apr 2018, 14:09
18 Apr 2018, 12:20
(180418.328)
update plex addon
release candidate 3
I'm not able to replicate any of the problem issues I had with the previous version. Everything is running smooth. I tried alternating from Opacity plex client to Plex Add-on, exit out, exiting to MrMc, full exiting. All is good. I think I'm even noticing more Plex video categories in the Add On? I was even able to "hack" a tvOS top shelf, until you get that working.
Post by cosmoxl » 18 Apr 2018, 14:16
before this is released will we get another shield version to make sure those problems are fixed as well?
Post by davilla » 18 Apr 2018, 14:18
cosmoxl wrote:
18 Apr 2018, 14:16
yes
Post by cosmoxl » 18 Apr 2018, 14:21
18 Apr 2018, 12:20
(180418.328)
update plex addon
release candidate 3
All good now
Post by cosmoxl » 18 Apr 2018, 14:25
18 Apr 2018, 14:18
cosmoxl wrote:
18 Apr 2018, 14:16
yes
ah, I should have looked before I asked. Looks like it updated overnight. :)
The problems I'd seen on Shield (crash on exit and no log via web GUI) are fixed now.
Post by cosmoxl » 18 Apr 2018, 14:45
Regarding the ability of MrMC to change resolution down, where is the limit? Reported EDID or Shield capability? I'm seeing only 720p as lowest resolution. Can the Shield output 480i if EDID reports that resolution is available?
Post by koying » 18 Apr 2018, 14:52
It's harcoded to 720p as minimum.
No clue what could happen with SD resolutions, I cannot test that.
Post by davilla » 18 Apr 2018, 15:18
Anyone try manual emby over https ? There were several requests for this. Just change the drop down from http to https
