Testing MrMC 3.6.1
Re: Testing MrMC 3.6.1
Post by davilla » 17 Apr 2018, 18:31
are you both running (180417.100) ?
Itzme1234
Post by Itzme1234 » 17 Apr 2018, 18:37
17 Apr 2018, 18:31
I am, yes.
Post by cosmoxl » 17 Apr 2018, 18:52
17 Apr 2018, 18:31
yes, according to testflight app.
system info of mrmc says 4272116-dirty
Post by timstephens24 » 17 Apr 2018, 20:22
iOS Plex addon is still the same. The main screen you can't swipe to navigate, you have to actually touch an icon to move the focus row. The icons are still stretched/not formatted properly. The touch areas in the settings are still off so I have to touch higher.
Biggest issue right now though is if I leave the app, going back I causes it to crash.
Post by amet » 17 Apr 2018, 20:37
timstephens24 wrote:
17 Apr 2018, 20:22
Is this on iPad? I am looking at it on the iPhone and is formatted okay, posters are not stretched.
Navigation is a bit difficult but I can control it just fine, touch works where I expect it to be... and it doesn’t crash :(
Edit: I see what you mean in home screen, I am not sure we can do much there... that’s how the UI is designed to require <ondown>/ <onup> to move to next row which we can’t do on iOS
Everbrave
Post by Everbrave » 17 Apr 2018, 20:40
iOS TestFlight:
On iPad Pro 10“
- The aspect ratio is still not correct; elongated in the vertical direction.
- touch control is also still erratic; swiping to the left causes the rows to scroll vertically
In summary, in its current state, I’d say, I won’t use the add-on on iOS but rather the native Plex app.
Post by timstephens24 » 17 Apr 2018, 21:23
17 Apr 2018, 20:37
Yeah on a 10.5 iPad Pro. I just looked on my iPhone and the posters are correct there. On my iPhone though it also crashed when I hit the home button, then went back into the app.
Everbrave
Post by Everbrave » 17 Apr 2018, 21:56
17 Apr 2018, 21:23
17 Apr 2018, 20:37
To be honest, I’d just skip the add-on for the iOS version altogether. It hasn’t been designed for a touch UI and I don’t think it’s worthy the effort to redesign the UI for touch, but it’s your resources 😉
Post by timstephens24 » 17 Apr 2018, 22:48
Yeah, I'd rather see other things (like PiP support and syncing files for offline playback) than work on the Plex add-on, but since it's a test thread I just post the issues that I see when trying to use it so they can come up with how they want to work things. No idea how long working on it would take, so it's always up to them to decide what they want to fix and what they want to save for later ;)
I also don't have an ATV set up and won't for about 3 more weeks while I move to GA, so I only have the iPad/iPhone to test things on.
Post by amet » 18 Apr 2018, 05:14
Files for offline playback is coming in a next version, it’s working but needs more testing and we didn’t want to delay this TestFlight release.
