Testing MrMC 3.4.1
Re: Testing MrMC 3.4.1
Post by davilla » 12 Feb 2018, 15:47
Montoya wrote:
12 Feb 2018, 15:40
10 Feb 2018, 22:20
v3.5.0 (180210.1903) @20180210-66d33d0
fixed, single/double/triple taps when scrubbing
fixed, crash if a control vanishes during render cycle
fixed, strm detection for scrubbing exclusion
Thanks for fixing strm detection for scrubber exclusion guys :D
One remark with that, when scrubbing exclusion is used:
When 3x tapping is used to skip FW/BW, subtitles are switched on and off.
Is this the standard right now for 3x tapping when scrubber exclusion is active and do I have to click now for skipping FW/BW, instead of tapping, or is this still something that is going to be fixed ?
The standard for native tvOS is click to ff/rw. Tripple tap toggles subs. This is standard when scrubber can be activated.
Clicks are the new hotty now. Taps are too easy to cause unintentional seeking.
Montoya
Post by Montoya » 12 Feb 2018, 16:09
Thanks for explaining and will use clicks from now on, because indeed, taps sometimes caused unintentional seeking with me too, when picking up remote.
Other question when using strm files:
Is it correct that when I play "moviename.strm", that "moviename.srt" is not recognized automatically, for showing external subs when they are present ?
Because maybe MrMC only looks for matching filename in the stream URL inside the srtm, for the matching subtitle srt.
This behavior is also present when a subtitle download via opensubtitles is done with MrMC, that the initial search query is the filename inside the stream URL, instead of the moviename.strm filename.
Post by amet » 12 Feb 2018, 17:43
think of strm as playlist, it just plays a link that you placed in it
Montoya
Post by Montoya » 12 Feb 2018, 22:34
OK, than MrMC treats strm files as playlist files and no functionality is yet present in it, to match moviename.strm to moviename.srt, to let MrMC show subtitles automatically.
So it is a feature request than and would be cool if MrMC supports strm<>srt matching, because I already automatically exported more than 2000 VOD movies from my iptv providers m3u, into strm files, to watch iptv VOD from a library instead of a VOD iptv channel.
SUPERBIF
Post by SUPERBIF » 13 Feb 2018, 08:58
SUPERBIF wrote:
12 Feb 2018, 08:44
On another note. When using the OSD channel guide in Live TV it doesn't go away automatically after switching to a channel.
Is that something that can be changed.
This is a bug. Can that be fixed?
Post by davilla » 13 Feb 2018, 14:24
Testflight for MrMC 3.4.1 is now closed. Testflight for MrMC 3.5.1 will startup shorty.
