testing MrMC 3.2.0
testing MrMC 3.2.0
Post by davilla » 23 Sep 2017, 21:29
How to request Testflight access: Send an email to support@mrmc.tv with the subject "I see dead people", include your email address tied to device, which flavor (tvOS, iOS or GooglePlay). Users that are already in testflight 3.1.0 are already in this series.
Released for iOS.
Released for tvOS.
Released for Amazon.
Released for GooglePlay.
Should be good for testing H265/tvOS11 on ATV4 and the new AppleTV 4K.
3.2.0 (20170923-fef1e4e)
emby: only lookup "connect.mediabrowser.tv" if net is alive
darwin: add identifier for appletv5
darwin: add and enable h265 hw decode for videotoolbox
darwin: temp disable DVDVideoCodecAVFoundation
backport, ActiveAE: some fixes and limit of max error
backport, ActiveAE: Fix up bytes skipped in SyncStream
backport, DVDPlayer: fix audio cache times, flush audio on resync if clock is far ahead
backport, AE: fix pause bursts
skin.opacity: add slider to scrobble on touch devices
skin.opacity: quit button on home for non apple devices
skin.opacity: slide show exit butonf0b2180905 darwin: fixed not running on main thread issues
(20170927-23a06f9)
core: we can silence this info log now
core: remove m_iVideoLibraryRecentlyAddedUnseen from advancedsettings and replace with GUI setting
tvos: add more 4K icons and images
darwin: fixed, ERROR ITMS-90718: "Invalid Image Asset"
backport: darwin - handle screen scale (first step in allowing native 4k resolution on ATV4 4K)
backport: darwin - another main thread fix needed by tvos 11 for the native keyboard
skin.opacity: sync with skin repo
(20170928-9408a78)
darwin: fix layout image to get 4K enabled under tvos
(20171005-001d85a)
backport, fixes in darwin osx sink
darwin: videotoolbox, refactor/cleanup to remove passed frameInfo, we already know pts from embedded CMSampleTimingInfo
darwin, audiotoolbox(ac3/eac3), strip padding and add parse frame size from header(future)
skin.opacity: fix hidden services on 4:3 screens
darwin, fixed mrmc-lite/tvOS app/launch icons
plex: separate vc1 and hevc local transcode settings
(20171008-bffe22c)
metadata.tvshows.themoviedb.org: upstream sync
metadata.tvdb.com: upstream sync
metadata.themoviedb.org: upstream sync
metadata.common.themoviedb.org: upstream sync
metadata.common.theaudiodb.com: upstream sync
metadata.common.fanart.tv: upstream sync
metadata.common.imdb.com: upstream sync
metadata.universal: remove Rotten Tomatoes as its no longer supported
core: log error if swr_init fails (CActiveAEResampleFFMPEG)
darwin: videotoolbox, tweaks and more cleanup
darwin: videotoolbox, refactor/cleanup and fixed crash and hang from sps/pps changing midstream
(20171010-ebda7fd)
ios: iOS11 keyboard fix
audioEngine: disable large audio sync error clamps
darwin: videotoolbox, handle h265 keyframes and force start if no key frames found in 64 demux packets
skin.opacity: fix missing texture
(20171010-f4ec9c4)
fixed crash playing 4K hevc content
(20171011-841fa65)
core: add fallback error checking if digit conversion fails and kick back setting value as string
(20171011-6b42792)
core: more hevc playback fixes
(20171012-8a27ae9)
darwin: exclude hevc from midstream sps/pps/vps change checking for VideoToolBox decoder
darwin: enable DVDVideoCodecAVFoundation and add setting for VideoToolBox decoder to include/exclude hevc/hdr content
(20171014-c27c925)
skin.opacity: extend top bar label
darwin: tweaks to AVFoundation/VideoToolBox regarding number of retained demux packets
(20171015-e390987)
pgs subs: some hevc/hdr content with pgs subs have wrong palette scaling
darwin: fixed crash AVFoundation if clock gets removed before process thread terminates
darwin: include FF_PROFILE_HEVC_REXT (HEVC_Main_422_10bit) in revector to AVFoundation, it is 10 bit video
(20171016-2f4f6f1)
darwin: audiotoolbox. refactor 14 byte paddign fix to only adjust if a 14 byte padding is detected, let everything else pass unchanged
skin.opacity: Revert "colorize focus texture with primary_color"
Re: testing MrMC 3.2.0
Post by timstephens24 » 23 Sep 2017, 22:11
Awesome, I'll check this out after finishing up a movie!
Ted377
Post by Ted377 » 23 Sep 2017, 23:43
Currently 3.2.0 (TestFlight) is not yet available.
Post by davilla » 24 Sep 2017, 00:39
Waiting for beta review. This always happens when the version number bumps.
Post by timstephens24 » 24 Sep 2017, 01:11
Oh well, no playing with new things today.
Post by cosmoxl » 24 Sep 2017, 14:45
In a hotel through the week, then moving into a temp. apartment in the new city. But, I hope I can help some with this testflight.
Post by davilla » 24 Sep 2017, 15:14
apple is being slow to beta review :( It normally happens within a few hours of pushing up.
Ted377
Post by Ted377 » 24 Sep 2017, 15:21
I think it will Release tomorrow.
Post by davilla » 24 Sep 2017, 15:33
Apple has done beta reviews over weekend before. Release reviews too.
Oh, also wanted to mention, any issues playing h265 will be followed up by a sample request :) There are two possible paths for treating packets provided by our demuxer. All the h265 samples that I have seem to be one flavor, so I am on the look out for samples of the other flavor.
loekf2
Post by loekf2 » 25 Sep 2017, 15:22
24 Sep 2017, 15:33
Silly question, what do you mean by "two possible paths for treating packets provided by our demuxer" ?
Do you mean there are two decoding paths for HEVC in tvOS ? I thought that everything goes through VideoToolbox.
What concerns me is how Apple deals with display modes, specially when the ATV 4K is running in "4K DV" or "4K HDR" mode. From what I've read (see the articles on Forbes and The Verge) is that video data written to the frame buffer (coming from apps or the UI) is output in HDR or DV regardless of being SDR, HDR or DV. Apple made the choice to adapt the video to the display mode (so SDR => HDR, HDR => SDR etc).
Imagine MrMC is playing a 1080p SDR movie (e.g. Bluray 1080p "remux" outputting REC709 YUV420). Suppose the ATV 4K is set to 4K DV mode.
Then the ATV 4K will upconvert the video to REC2020, apply ST2804 inverse transfer function etc.. so do a lot of post-processing. Guess this will introduce extra latency and of course make the video look worse.
There is a lot of controversy about this. Unfortunately I don't have a 4K TV yet.
Is there a way you can circumvent this Apple post processing ?
Oh btw.. can MrMc output HDR video ?
