testing MrMC 3.0.9
Ted377
Re: testing MrMC 3.0.9
Post by Ted377 » 12 Jul 2017, 10:50
Everything works fine on the Apple TV. I have nothing to complain about. 👍🏼
Post by davilla » 13 Jul 2017, 13:05
3.0.9 (170713.340)
fix 206 HTTP we are getting from RSS feeds
fix possible crash when checking CheckLibLoadedAndLoad()
fix crashes in glrKillClient when we try to render while in background on iOS/tvOS
fix EDL lists
regression - bring up channel list on LiveTV on Select(hold)
Post by cosmoxl » 13 Jul 2017, 21:52
13 Jul 2017, 13:05
3.0.9 (170713.340)
fix EDL lists
Any idea what to look out for regarding problems from the EDL list fix? I can't test the EDL handling itself (I don't use comskip or whatever) but since you say it involved critical code.....
Post by davilla » 14 Jul 2017, 00:51
just normal playback/seeks
Post by cosmoxl » 14 Jul 2017, 00:56
14 Jul 2017, 00:51
We watched a movie earlier. I didn't notice any problems.
Post by davilla » 14 Jul 2017, 01:07
cosmoxl wrote:
14 Jul 2017, 00:56
14 Jul 2017, 00:51
As it should be :)
The EDL fix 'should' not effect anything else but the code is rather twisted down there so we are looking to see if any corner cases pop put.
BTW: this version is what we consider to be a release candidate. Which means testflight 3.0.9 series is drawing to a close.
jabohn
Post by jabohn » 16 Jul 2017, 02:46
Thanks for all the hard work - looking forward to the next release!
Post by davilla » 17 Jul 2017, 16:49
testflight 3.0.9 is now closed. testflight for 3.1.0 will startup shortly.
1st thing in testflight for 3.1.0 will be more EDL fixes and once that settles out. New skin :)
