testing MrMC 3.0.9
Re: testing MrMC 3.0.9
Post by amet » 10 Jul 2017, 22:29
3 options... :)
- shared MySQL data base
- plex with trakt plugin
- emby with trakt plugin
- BONUS option, hold on tight for 3.1.0 :)
I have MrMC in daily use on 4 different boxes, and another 5-6 dev boxes... never used trakt in my life ... but I promise that it will be in a next TF, just for you
Post by timstephens24 » 10 Jul 2017, 22:44
Haha I appreciate it, really do. You guys are the best.
jabohn
Post by jabohn » 10 Jul 2017, 23:18
10 Jul 2017, 13:05
3.0.9 (170710.651)
- fix for resume playback while testing Trakt
RC, if all is good, we will move this one to release
Resume fix confirmed here!
Post by davilla » 11 Jul 2017, 18:08
timstephens24 wrote:
10 Jul 2017, 22:44
Just for you :)
3.0.9 (170711.1549)
- add trakt autoupdate
Ted377
Post by Ted377 » 11 Jul 2017, 18:42
I am now downgrade from tvOS 11 to tvOS 10.2.1. Will test TF afterwards.
Post by timstephens24 » 11 Jul 2017, 19:27
11 Jul 2017, 18:08
10 Jul 2017, 22:44
Just for you :)
3.0.9 (170711.1549)
Woooooo, thanks guys! I just tested it out and it works beautifully. I love it!
jabohn
Post by jabohn » 11 Jul 2017, 22:36
So now Trakt updating should happen when you play a file and when you update your library? Just wondering which instances to watch out for.
Post by timstephens24 » 12 Jul 2017, 00:24
When you watch a file it'll tell trakt that it's watched; but I'm not sure what percentage of watched they set it at. You have to choose the setting to either pull trakt status or push trakt status after a library update (or don't change it and it won't do anything after a library update). I have it set to pull trakt status.
Post by timstephens24 » 12 Jul 2017, 00:25
I sent a crash report on the Shield, it crashed when I switched from the MrMC skin to the Amber skin, but I couldn't reproduce it so I'm thinking it could have been a one-off.
Post by davilla » 12 Jul 2017, 01:43
12 Jul 2017, 00:25
Had one reported 25mins ago, something in libdsm but app version is 17062603, so not MrMC 3.0.9. Before that was Jun 28, 4:12 PM. I'm not sure google even reports beta release crashes :)
