testing MrMC 3.0.9
testing MrMC 3.0.9
Post by davilla » 28 Jun 2017, 15:58
How to request Testflight access: Send an email to support@mrmc.tv with the subject "The cuss you are", include your email address tied to device, which flavor (tvOS, iOS or GooglePlay). Users that are already in testflight 3.0.7 are already in this series.
Released for tvOS/iOS.
Released for Amazon/GooglePlay.
With this series, we move to 10.2 min for iOS/tvOS. VideoToolBox is refactored to linked in rather than dyloaded and for tvOS, it is set to be enabled by default. This is also the start of Trakt support, push only right now.
(20170628-a7d0c09)
Update to 10.2 min
Updates to VideoToolBox
Added Trakt support.
3.0.9 (170701.1848)
plex: fix listing genre -> tvshows
fix 3rd party remote navigation
3.0.9 (170702.2020)
plex: SetProperty("album_description”) based on plex album review
trakt: dont report progress on pvr items
trakt: fix reporting of watched item after we go over 90%
core: tryfix for emby/plex woa
core: tryfix for plex/gdm without access to internet
3.0.9 (170704.1958)
backport: keyboard fixes for iOS/tvOS 11
core: disable and hide AVFoundation codec (not ready for primetime)
core: add dateadded to core settings (lost in a meger)
3.0.9 (170707.1006)
- trakt: add more logging
- trakt: set number of plays as per trakt
- tvos: make rew/ff 4x as it was
- RSS: fix reloading of rss when profile changes
3.0.9 (170709.1449)
- trakt tryfix for crash
- core: fix lighteffects screensaver deactivate
3.0.9 (170710.651)
- fix for resume playback while testing Trakt
3.0.9 (170711.1549)
- add trakt autoupdate
3.0.9 (170713.340)
fix 206 HTTP we are getting from RSS feeds
fix possible crash when checking CheckLibLoadedAndLoad()
fix crashes in glrKillClient when we try to render while in background on iOS/tvOS
fix EDL lists
regression - bring up channel list on LiveTV on Select(hold)
jamesp26
Re: testing MrMC 3.0.9
Post by jamesp26 » 28 Jun 2017, 22:25
So far no issues. Anything in particular we should look out for?
Post by davilla » 28 Jun 2017, 23:29
jamesp26 wrote:
28 Jun 2017, 22:25
Not sure yet :) The bump to 10.2 api touches just about everything but 'should' be ok. Hopefully this will be a painless version bump (unlike the last one :)
Post by cosmoxl » 29 Jun 2017, 00:03
I didn't notice anything different except AVFoundation choice is exposed. What's to come of that?
Post by amet » 29 Jun 2017, 04:48
anodyne tried Trakt.tv?
Post by davilla » 29 Jun 2017, 13:07
cosmoxl wrote:
29 Jun 2017, 00:03
AVFoundation is an experimental decoder for darwin platforms. Potentially even less CPU usage than VideoToolBox. Similar to MediaCodec (surface), it bypasses the normal render path and decodes direct to a view (surface) that is under the OpenGL view. Work-in-progress.
It's been exposed under iOS for some time now. With the move to tvOS 10.2, we can finally expose it under tvOS too.
Post by cosmoxl » 29 Jun 2017, 13:55
29 Jun 2017, 13:07
cosmoxl wrote:
29 Jun 2017, 00:03
So would you like me to leave it alone for now? :)
Post by amet » 29 Jun 2017, 13:57
I think the whole idea is that you should abuse it as much as possible :D
Post by davilla » 29 Jun 2017, 14:47
cosmoxl wrote:
29 Jun 2017, 13:55
29 Jun 2017, 13:07
cosmoxl wrote:
29 Jun 2017, 00:03
Depends on how you like having pins stuck in your eyes :)
rohitrs7
Post by rohitrs7 » 29 Jun 2017, 14:55
Does this have HEVC support on TVOS?
